95 Gmc Sierra Gears
hello i see there is a lot about 35 inch but i was just woundering what gears i should use with 38 inch on a 95 gmc serria 5.7 lit 4x4 i have 33s on it now and it has robed me of a lot of power so when i put the 38s i know i have to change the gears but not sure what ons to order any help guys thanks
and would i half to change the front ones to ?
Yes, you need to change the front gears as well. To be properly geared for 38s, you'll need either 4.88s or 5.13s, both of which will wreak HAVOC on your truck with 38s. 38s are just plain too damn big for half ton suspension and axles.
Doood listen to thi guy^^^ he is the supensin god!
Doood, don't listen to this guy, he's drunk off his ASS. :crazy:
I still stand by what i said though. :D
thanks guys for the fast reply so it would be a good idea to put in solid axels oor just take and put ones in out of a 3/4 ton also putting in a 4inch suspention lift with 2 inch body thanks guys
No way you're going to fit 38s with only 6" of total lift. Just to fit the tires, you'd need at least a 6" suspension and a 3" body lift, and you'll still probably need to do some trimming.
But the only way to safely run 38s is to do a solid axle swap.
Don't forget stopping.With the extra weight & rolling mass I wouldn't be too confident on getting that thing stopped too quickly...
So you're looking at a pricey 9" total lift, 3/4 ton axles, and larger brakes all just to get 38" tires. I highly suggest getting something and inch or two smaller. A 36" tire, for example, would only decrease your ride height by an inch over 38" tires. Pretty minuscule and a lot more affordable and reasonable.
:thumbs: hey thanks for the replys guys sorry for the long time had to put the truck on hold for a whil just went to start it and wham of all things had a hart attack just got out of hospital and half to rest for a bit will start back as soon as i get better and i think i might save all probs and go with 36 inch and a 4inch sup lift should be lots for a half ton i think k thanks guys again
:thumbs:
