Rear End Gears
Why is that?
A lower (numerically higher) ratio develops more power per revolution of the driveshaft.
4.1 revs of shaft per rev of axle. This is desireable for heavier loads.
4.10 is better for towing because it multiplies the torque of the engine more efficiently and provides more power for moving heavy loads.
4.10s will put your 5.3 in it's "sweet spot" when towing allowing this relatively small engine to handle some significant loads. Not sure what you are towing but let's assume it is a 6,000 lb camper. Towing this load in 3rd at 55 or 60 will have your engine right where it wants to be with this load. If you move to 4th, you would find you would need to increase your speed to around 70 to keep the RPMs in the same range. I personally do not like towing at speeds over 60 to 65 so I simply run mine in 3rd and keep it under 60.
When I say "sweet spot" I am talking about the minimum RPM the 5.3 will turn and remain in the prime torque band. I cannot speak for the later models like yours, but my 02 really comes in strong around 2,220 RPMs and will maintain my speed or accelerate from here with my camper in tow and on a moderate hill. It seems to have plenty of power avail from 2,200 to 3,000 and is comfortable running at these revs. It will pull from 2,000 RPMs and less but the power and tq are not readily available.
I really like to keep it around 2200 to 2400 when tuggin my camper. It just seems to be "happy" in this range.
What I mean by 3rd is Drive, not overdrive.
If you are towing in OD you are likely running speeds above 65 on flat ground or your transmission is downshifting a good deal to drive.
Because I am typically towing on 2 lane roads with speed limits of no more than 55, I elect to keep it in 3rd with the Tow Haul Mode engaged and keep my speed around 55. As I said before, if towing on the Interstate and you are comfortable towing above 65, you can put it in OD and let it go. For me, it is all a matter of keeping the revs in the 2200 range while driving at a safe comfortable speed.
I would be interested in knowing if you are using 3rd or 4th and what speeds you tow at as well as the roads you tow on (flat or hills)???
Why is that?
i.e. The same reason you shift your bike into 1st gear when pedalling up a steep hill. :)
I keep it in drive with the tow/haul button in and do about 60 on the highway and 45-50 on side roads(always in drive). I never have dropped it down a gear when towing , i don't find it revs all over the place!
I meant a 6000lb TT! So all and all my speeds around 50-65!
Do you do a lot of towing! What are you towing if so.
    • Getting greedy...   The AC pump has been replaced at least once per service records, and it's been recharged twice since 2018 or so, in approximately 2 year intervals between those charges.   It was done at the same shop...clearly they were enjoying the revenue of recharging the system periodically versus actually tracking down and fixing the leak. I learned that the owner was 88 years old when she passed in 2023, so maybe they assumed only a temporary fix was needed anyway.   The system is basically empty now, the compressor spins freely, so I'm guessing it "just needs a recharge".   I vacuumed it down, and it has basically held overnight. Doesn't appear to leak under vacuum, check! So it must leak under pressure. I don't have a way to pressurize the system and pressurizing it with shop air wouldn't be great for the air dryer (which is probably toast anyway?)   The dryer (accumulator? I'm not an AC expert) has a Schrader valve, but the high side has an old ball-type valve, which are notorious for leaking. It's clearly had schmutz blown out of it at one point because the line/area next to the valve is coated old black crud, which I assume is AC refrigerant residue/oil, or maybe even dirty dye. I think I'll roll the dice and replace the valves. I have a black light around here somewhere so I'll find it and shine it around the engine bay in the dark to see if there's any dye.   I can't think of another way to track down the leak other than injecting some dye (if it doesn't have any) and having it charged up. We can't buy R134a off the shelf here anymore, so I'll run it up to Jiffy Lube and have them do it. I think I have a coupon. At the very least, the charge should last long enough for a year or two, according to history. I think this truck will be long gone by then. But cold AC is a selling point.
    • Got the truck back today.  Called them yesterday to get an update, and miraculously my truck is finished?!?! The $13k out the door was complete bullshit!  Ended up being over $14k.  They added some bullshit service bulletin that I cant even find, where they replaced my radiator without telling me or asking me, and charging me for it.  Need to do more research into it, cause they leaked the first delivered radiator was ran over by FedEX.  Sounds like bullshit to me. 2.5 Months for an engine swap, which ended up being remanufactured, not new; ****ing ridiculous.  Brakes are squishy as hell, not sure if its from sitting.  Will give a couple days to see it that figures it self out.  GAVE IT BACK TO ME WITH 1 GALLON OF GAS!  Just filled the tank the day before drop off, more bullshit.  My dash cam SD card was formatted, not really much I can do about that. 3 year, 100k GM warranty at least.  Time to sell it and say **** off to GM.  Bad experience.  Cant wait for the survey email to come through.  Overpriced Raptor R, here I come!
    • If I forget the phone in the truck, and forget the truck in the phone, and reconnect.  It works great for the day.  Truck sits overnight, and the next day is a no go.  It will connect Android Auto via usb cable, but not bluetooth.   Ive tried Everything in this thread so far, and nothing works for more than a day.   I think I might have to go to the dealer and have them flash the pcm.   thanks for all the suggestions guys. 👍
    • 2022 2500HD Crew Z71 Duramax single alternator.  Recently had the primary (water pump / fan) belt tensioner pulley bearing to fail while hundreds of miles from home of course the plastic pulley melted and belt shredded which took out some wiring. Found a replacement tensioner assembly and belt to continue now would like to find a replacement for just the pulley and bearing to have a spare assembly in case of a repeat, the rest of the tensioner is fine. Has anybody here found a correct replacement part for just the pulley and bearing? Any help is appreciated.
    • +1 for the 3.0   Perfect for 1500 pickup towing duties.   Perfect engine for a 1500 pickup period. Huge torque at stunningly low RPM makes it feel a lot lighter than it is. The fuel mileage is insane for a tall and heavy 1500... 30+ on the highway. Mid 20's around town.   It's probably not perfect if you bought a 6.2 for the braaaaaaapppppp V8 noises and wrapping it out to 6k. The LZ0 acts and sounds like a small turbo diesel and there's nothing you can do to make a small turbo diesel sound like a big one, and you can't make an inline diesel sound like a V8 diesel/big Duramax. It's a different driving experience altogether.   Drive one, I think you'll like it, though...
