Another New Guy
Owned Chevys all my life and just bought a new 09 extend cab on the 24th of April. At 51 years of age I am old school enough that I hate alot of the new technology being forced upon us. Thanks to the internet I was able to unhook the onstar system after being told by the dealership it couldn't be done.
So now I am on another quest. Anyone know how to disable the alarm system? I refuse to carry a huge fob in my pocket. As soon as I unlock the door with the key, the horn starts making short beeps and if I don't start the engine immediately, the alarm starts. I am not at all worried about someone stealing this truck in the small town I live and work in.
Any help would be apppreciated!
Welcome! We'd love to see some pictures of your rig. :thumbs:
I can't help on the alarm, as mine doesn't have one, sorry.
Thanks for the welcome. I see in your signature that you own a Night Train. Have an 06 Night Train myself with big bore and springer front end and a VRod
NRS015.jpg.
Nice rides! Sadly, I'm putting my Night Train up for sale. 2 and 5 year olds don't leave a lot of time for riding at the moment...
Welcome to the site... Not sure either about the alarm.. but someone here might. Not a request I've seen to often myself.
You have one Karl...Its part of the keyless entry system.
Ah...guess I like my keyfob then...Don't think I've ever put the key in the door. Might not even be the right key! :thumbs:
I was going to guess that it could be shut off in the DIC, but i'm betting he doesn't have that given that he said he doesn't like all the new-fangled crap :lol:
Heres the description on how the system works....
Content Theft Deterrent (CTD) Description and Operation
When armed, the content theft deterrent (CTD) system is designed to deter vehicle content theft by pulsing the horns and exterior lamps for approximately 30 seconds when an unauthorized vehicle entry is detected. However, the CTD system does not affect engine starting.
An unauthorized entry can be any of the following with the CTD system armed:
• When any door is opened without first being unlocked using the keyless entry transmitter
• After a battery reconnect, if the battery was disconnected with the CTD system armed
The components of the CTD system are:
• Body Control Module (BCM)
• Security indicator
• Door ajar switches
Arming the CTD System
Use the following procedure in order to arm the system:
Place the shift lever in P (park).
Turn OFF the ignition.
Open any door.
Important: The system is not armed if the doors are locked manually; the power door lock switch or remote keyless entry transmitter must be used to arm the content theft deterrent (CTD) system.
Lock the doors with the LOCK button on the transmitter. The system is in standby mode and will not start the arming timer until all doors are closed.
The system will begin the arm sequence immediately after the last door is closed. If the keyless entry transmitter is used the arm the system after the vehicle doors are closed, the arm sequence will begin as soon as the LOCK command is received by the transmitter.
Locking the Vehicle Without Arming the CTD System
Locking the vehicle may be accomplished without arming the content theft deterrent (CTD) system. Use of the manual door locks or using the key to lock the doors will lock the vehicle, but will not arm the CTD system.
Disarming an Armed System/Silencing an Alarm:
If system arming has been requested by the power door lock switch or the keyless entry transmitter, it must be disarmed.
Important: Using the power door unlock switch or manually unlocking the doors does not disable the content theft deterrent (CTD) arm mode. Also, disconnecting the battery or pulling fuses does not disable the arm mode, since the BCM stores the CTD mode status in memory.
• To disarm the CTD system in standby mode, perform one of the following:
- Press the UNLOCK button on the keyless entry transmitter.
- Insert a valid key into the ignition and switch to the ON position.
• To disarm the CTD system in the armed mode (non-event) or when activated (during an alarm event):
CTD Circuit Description:
The following is a description of each component used in the content theft deterrent (CTD) system:
The CTD system is an internal function of the BCM which utilizes serial data and various switch inputs information to perform CTD functions. When the BCM detects an unauthorized entry, it activates the horns and exterior lamps. The BCM has 4 basic modes (disarmed, standby, armed, and alarm) for operating the CTD system. The different modes are described below.
The BCM has the CTD system in a disarmed mode until the following conditions are detected:
• Ignition key turned to the OFF position.
• Doors locked by either the power door lock switch or the LOCK button on the transmitter.
The BCM enters the standby mode when the above conditions are detected. If a door was already opened when the arm mode was requested, the standby mode does not start the timer until the last door is closed.
When the last door is closed, a 15 second timer is activated. Once the timer has expired, the BCM enters the armed mode. After this delay, any forced entry activates the alarm mode.
When the BCM detects a forced entry, the BCM enters the alarm mode. The BCM activates the horns and exterior lamps for 30 seconds. This is followed by a three minute time-out with the horn no longer active. If no new intrusions are detected after the time-out, the horn is not active. The system must be disarmed or the intrusion condition removed after the time-out for the system to exit alarm mode.
Security Indicator
The security indicator is illuminated on the instrument panel cluster (IPC) by the BCM for CTD or the immobilizer system. The CTD system uses the security indicator to inform the driver of system status prior to arming. The security indicator on the instrument cluster is controlled by both the CTD system and the immobilizer system.
• The CTD system, integral to the BCM, commands the IPC to control the security indicator only when the ignition switch is OFF. The CTD system uses the indicator to identify system status.
• The immobilizer system commands the IPC to control the security indicator only when the ignition switch is ON as a malfunction indicator. The immobilizer system is to deter vehicle theft. Refer to Immobilizer Description and Operation for more information on the immobilizer system.
Door Ajar Switches:
The CTD system uses the door ajar switches as a status indicator to activate the alarm. The door ajar switches are monitored by the BCM via a discrete input from each door ajar switch. If the BCM receives a signal indicating a door is opened when the CTD system is armed, the BCM activates the alarm.
Inputs
The BCM monitors the following inputs for CTD:
• The door ajar switches
• The keyless entry transmitter LOCK/UNLOCK buttons
• The immobilizer status--The BCM uses the immobilizer status for disarming the system or silencing an alarm when the correct vehicle key is used to start the vehicle
Outputs
The BCM controls the following for CTD:
• The horn relay
• The exterior lamps
