Fair Price For 07 Denali With 48k?
I saw this while looking through cars.com One owner is good. It looks like there were some long intervals between oil changes towards tradin.
06/19/08 34,624 oil change
12/02/08 45,109 oil change
Whats a good price for this or should i continue looking?
http://www.cars.com/go/search/detail.jsp;j...mp;aff=national
CARFAX
http://www.carfax.com/VehicleHistory/p/Rep...p;partner=COO_0
Seems like a fair price to me. It's loaded: 20" rims, nav, etc. I'd shoot for around 24 or something, but that price is certainly in the right ballpark. Check Edmunds.com TMV and see what it comes up with. As far as the oil goes, it's certainly possible that the owner was just following the advice of the OLM, and that his or her particular driving habits made for long intervals. It's also possible that the oil was changed elsewhere in between.
I would offer him 500 to 1000 over trade in..that thats IT...
lets face it....gas is on the way back up, the economy is still taking a crap, and MPG's on the Denali's is not the best, and its harder to get rid of.
The truck looks good tho.
that is my .02
i would keep looking. the guy didnt take care of it
How do you come to that conclusion from the information provided?
Truck looks like to be in mint condition and that is one hell of a deal. Has all the options too minus the running boards.
LOL! Thanks for your opinions guys. I am still on the fence, I guess I will give it some time and see if its still there waiting for me. Texas is a good 500+ miles away from me...
Hmmm.... Now its not showing in the search results?
Seems like a damn good deal to me. Especially considering this is Texas. Here trucks have been and are still selling great.
If I was still looking, I would be all over it.
seems very fair priced to me based on prices around where I live. not sure what prices are like in texas for that truck... but it still seems very fair either way. Only thing I wonder after looking at the carfax is why he only changed the oil every 10,000 miles. Perhaps he used synthetic I suppose which would permit the 10,000 interval.
Anyways, a good deal. I would start the offer $24,500 tho if you are interested... no need to let the dealer profit much over what the gave him for the trade-in
CARFAX
Well I was going to keep this under my hat, but I bought my 07 GMT900 2wd Denali with ALL of the options except running boards, and the 20" wheels (Mine has the 18's) with 22,235 out the door for 26,500 in December. I bought it from Huffines in Lewisville which is about 25 miles north of Texas Cars Direct (I live in downtown Dallas). I would take Bostonsfavson's advice and start at around 24,500.
    Greg3160
    Greg3160
  • Who's Online   2 Members, 0 Anonymous, 486 Guests (See full list)
    • Late reply, but yes—it works on the SLT trim. Compatibility comes down to the plastic shroud shape behind your mirror, not the trim badge itself. On the SLT with auto-dimming, it uses a plug-and-play Y-harness off the mirror/rain sensor power, so no need to run wires down to the OBD port. If anyone's ever unsure about fitment, just drop a photo of your mirror housing and we can double-check it.   Appreciate the detailed feedback on the install! On the windshield glare—we actually took feedback like yours and developed a dedicated CPL (polarizer) filter to cut down dash reflections on sunny days. If you're still running the cam, shoot me a DM. I'd be happy to send a CPL filter over for you to test out—no charge.
    • There are no stickers in your glovebox?
    • Look at the numbers on the stickers in the door jam...
    • Yes, every time the developer updates his code, you must recompile. I will private message you with the latest because it changes pretty much with every version.
    • After I wrote that reply I went for a ride. 85 F out. So trans started at 85 F and it shifted the same as it did an hour latter at 168 F. I've never actually recorded the to cold to shift point but it is under 32 F before they start hanging on to a lower gear or leaving the converter unlocked. Both intended to heat fluid.    Yes, brake or bake. Absolutely.      Your welcome. True research ended decades ago. Field trials are still in play.    There is a thing called oxidation onset temperature. This is the heat related oxidation not the O2 exposure kind. For mineral oil that starts at 140 F. So what happens after 140 F? Each 20 F cuts fluid life in half! Does using a Full Synthetic improve that? Yes! By how much? Depends on the base oil type and a few other factors. But enough to notice. Some esters are even higher. There are even synergies between types the will raise it higher than any one component is alone.    Then there is "Hindered" oils. Antioxidant additives. Hindered Polyol Esters can sit at 500 F for years in a turbine.   When a blender brags his oil will 'take 500 F" in service he doesn't specify for how long. Water will dance on a 500 F hot plate for several seconds. @newdude put up a chart showing the relationship between fluid temperature and it's life in an automatic transmission. Here's a version of that chart for Group III based oils. These temperatures are those in the pan as observed as 'normal'. that is you drive as you do for as long as you do under what load you ask of it and whatever that temperature is this graph applies to. Flash temperatures of a few minutes isn't what his means.    Note that fluids held at a constant 240 F have a service life of only 20K miles. 220 F explains the factory exchange limit, eh? My equipment I keep under 180 F and I'm good if the cooler will hold it as low as 140 F. But that's me.
