Whut It Deww
Wassup y'all!
I have a 2005 Chevy Colorado ZQ8 Xtreme that I bought new in late August of 2005. I use the truck for work and for play and now have over 100k mile.
Welcome!!
Thats a sharp lookin' Colorado :D
welcome, but I didn't think they made a colorado extreme? I know the s-10 type was a zq8 but not the colorado never heard of that model.
Thanks for the welcome everyone!
Now you have  :lol:
