Tire Pressures?
ok i was reading my door sticker today and i swear it said 60psi up front and 80 psi in the rear? am i just retarded or reading it wrong or what? The sticker called for 245 75 16
there was another thread where we were talking about this...
that 60/80 is loaded weight (and make sure you only run that if your new tires are rated up to 80 PSI).
You could probably run 40-50 PSI all around and then up the pressure if you're hauling. At 80 PSI you'll get horrible wear unless you have the bed loaded
hmm its got 265 75 16 on it now would they be near the same? wow i could gain some MPG im runnin 36psi all around shit too used to 60's mobiles.
If you put that much air in, you'll swear somebody replaced your tires with solid steel ones. I run 32PSI
ROUGH!
ROUGH!
solid steel tires would make one sweet burnout! :rolleyes:
ROUGH!
hahahah, yah, but the clown is right rough ride, even at 50 psi!
ROUGH!
Heck yeah! We could call you Sparky
The sticker on my truck is 50 front, 80 rear. I have all 4 of them at 60, and they are 10 ply tires. The ride is nice on the highway, but you can tell she's a truck on pothole filled roads. :P
You need to go by the specs for the tire on your truck now. The sticker is for the tire that the truck came with from the factory. For instance, my 1/2 ton has e-rated tires I keep between 50-52 psi. The sticker says 30 psi.
    • thanks for coming back and posting what the fix turned out to be.
    • Only TAN I have for the product was at 5K in service miles and it was 2.71
    • If anyone lands here looking for an update - the problem wasnt with the hose, the clamp, etc... I purchased a metal Thermostat housing that just must not of been made to spec. It just wouldn't plug up the hose.. Went back to a plastic cheap housing - leak fixed. Some plumbers tape carefully placed in tandem with a clamp likely would've gotten the job done.   Best,
    • For anyone following, this is what I have deduced from this forum - and my very specific niche case. Please do let me know if you see me going in the wrong direction here. For context, I have a 16 sierra 1500 w/t. Has TC and Cargo light switches. Removed the switch to find the X1 and X2 of the S48A connection populated with wires (x1 10-14, and x2 1-5).   Took photos of the X61A-X5 to find the wires from S48A-X1 land here at their respective pins (10, 11, 17, 23 on the X5). Was hopeful that this means my X51A fuse box has the appropriate pins... No cigar. So now I will be routing wires from the rear of the X61A-X1 to the engine bay and to their respective negative relay triggers. Please see to the diagram. If any has insight as to where the S48A-X2 pins 4 and 5 land that would be awesome.   Note: please disregard fuse sizes. Main fuse will like be 25A, all mini bus fuses will likely be 10-15A   Cheers
    • 287,500 Mile Service   8/13/2026   Reset Fuel Trims   Since the work done in the previous post there was a good improvement in response in all areas except right after a fill up where the LTFT would go -20%+ for about four miles while the STFT was near neutral. Before the work they both went very negative for a few miles after a fill up but act normal thereafter.    We did a systems check of the vapor recovery system for functionality and ability to hold a vacuum. That checked out fine. But this doesn't mean the charcoal canister is dead in the water. Testing that is next up. For now the reset of the fuel trims.    I intentionally shorted the fill exactly two gallons to eliminate any chance of filling the canister. On start up the trims were behaving normally until I got up and rolling where the LTFT went -10 / -11%% but the short was + 2 to 0%. Within a mile the the STFT offset the LTFT and by 2 miles they were neutral. HUGE improvement but still not hunky-dory.    I'll watch them for a few days. Perhaps another tank where I will fill completely to 'first click' and compare. Meanwhile on the hunt for a new canister and I'll toss another purge value at it for good measure. Pending the outcome of the canister test that is. Progress of any kind is welcome.    Fuel economy improvement with bringing hole #3 back to the living was a noticeable bump to the positive. Even on the few miles I drove after the refill I already see another bump up by the trims reset.     She's purring like a kitten with a warm bowl of milk.    BTW, adding 50 rpm to the idle took the majority of the negative timing out on cold start up and leaned the cold idle. No longer burbles in the cat. What a dumb way to heat a cat.
