Engine Coolant Hot
From what i can dig and find out the heads with 706 casting have had a problem with very fine hole in and around the head bolts allowing coolent to seep and evaparate inside the head itself. Sorry to give bad news but I found a place online that had a service bulletin for motors with less than 50,000 miles. Sound funny to me if they know they have a problem they should fix it.
Can you give me the link where you found it? Just in case my water pump doesn't fix the problem, it gives me a point to argue with my accountant.. err i mean my wife..
999999995.gifSubject:Information on Gradual Coolant Loss Over Time with No Evidence of Leak Found #06-06-01-019B - (06/12/2007)
Models:2004-2006 Buick Rainier
2001-2006 Cadillac Escalade Models
2001-2006 Chevrolet Avalanche, Blazer, Silverado, Suburban, Tahoe, TrailBlazer Models
2001-2006 GMC Envoy, Jimmy, Sierra, Yukon Models
2001-2004 Oldsmobile Bravada
2005-2006 Saab 9-7X
with 4.8L or 5.3L VORTEC® GEN III, GEN IV V8 Engine (VINs V, T, M, B, Z -- RPOs LR4, LM7, LH6, L33, L59)
This bulletin is being revised to include engine RPO L59. Please discard Corporate Bulletin Number 06-06-01-019A (Section 06 - Engine/Propulsion System).
Some vehicles may experience a gradual coolant loss over time. A very low percentage of cylinder head(s) manufactured with an embossed Castech logo may develop a porosity crack in a very specific area.
Inspect the cylinder head assembly to determine if the casting was manufactured by Castech. This can be accomplished by inspecting for their casting logo located on top of the intake port, under the rocker arm support rail and in the spring deck cavity portion of the cylinder head.
Important: If the cylinder head(s) are Not a Castech casting, follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
Refer to the following illustrations on how to identify Castech casting and/or the very specific areas of the cylinder head(s) for a coolant leak from porosity.
Cylinder head(s) location of the Castech manufacturing casting logo (1).
Close up view of the cylinder head(s) showing the Castech manufacturing casting logo (1).
If the cylinder head(s) is a Castech casting (1), inspect the area around the five oil drain holes for witness marks indicating coolant seepage over time (2).
Important: If No evidence of coolant loss is found on inspection of Castech casting cylinder head(s), follow normal diagnostic procedures in SI to determine the cause of the coolant loss.
The crack location can be found in any of the five cylinder head(s) oil drains. This can be seen as a clean or shiny area, on an otherwise stained surface (1). Pressurizing the cooling system at this time may reveal coolant, air, or a combination, weeping in the described area. If inspection reveals evidence of coolant witness marks (1), replace the entire cylinder head(s) assembly.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gifWE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
</SPAN>
2005-2006 Saab 9-7X
</SPAN>
Do you know what cylinder head casting numbers come from Castech or which one(s) have been known to be defective? Since this is a known issue with Castech heads will GM replace them at no charge?
does anyone know if this problem is with all Castech cylinder heads or did Castech have process variation that would allow some bad and some good parts?
I have the exact same problem with a 2005 GMC 1500 crew cab. I have had 2 places check it out (it has a water pump less than 2 months old) with both scatching thier heads. My heads have 706 stamped just underneath the valve cover i have read that people have had problems with them. Sorry to jack your thread just odd we have the exact same problem. Let me know waht you find out.
Mrkleen,
I hope you have better luck than I do. I replaced the water pump and checked today... coolant getting low again... another buddy thinks he smells coolant under the hood while it is running, but still no visible leaks. I am going to park it for awhile until I can get the time to pull the heads apart. :P
  • 4 years later...
I have a 2007 Chevy Silverado 1500 and today while idling for about half an hour to recharge the battery, the "Engine Coolant Hot" light came on. I have refilled the coolant tank and did a test drive when the temperature topped out above 220. I turned the heat on high (as suggested in the manual), but the entire trip it blew out nothing but cold air. Any suggestions?
Sounds like a blockage or major leak near the heater core. If the coolant isn't circulating correctly it could overheat and boil over, have you been smelling coolant? This would also prevent the hot coolant from getting to the core, which is what makes the heat.
