Arggg! I Need Hd Radio
OK, I was at the dealer getting my battery replaced under warranty. After picking it up, I noticed that the radio was playing some music that I charactorize as being "south of the border". No problem, I figured the tech wsa listening to a station of his choseing whilst repairing said vehicle.
However, I noticed that it was on my favorite Smooth Jazz station preset. At first I thought, WTF..I moved around the dial, came back to to it and sure enough the format changed suddenly. For those in the Chicago area it was WNUA 95.5
So I get home, fire up their webpage and notice a letter announcing the format change. However, the original format is still availaable on HD radio. Of course, I do not have HD Radio, just a non-subscribed XM radio module that is wasting space and electrons. I recall that an XM to HD module was in the works or being discussed.
I have the Nav unit that I tolerate and XM is overpriced, sneaky and overcompressed to warrant my exchanging of Federal Reserve Notes to their keep.
So what is the word on the street for this option?
I brought this up to Chris at CoSTAR Tech, and he seemed interested in the concept, but I think he's still busy completing a complete line of BlueSTAR kits for the GM line. I did start a thread on the CoSTAR website forum, maybe if there was a show of interest he may up the priority for the development of an HD Kit for our vehicles. Here's a link to the CoSTAR Forums Thread.
i just bought a new jensen VM9312HD screen with HD radio (my jensen VM9312 screen was stolen so i upgraded) and it sounds great and wasnt that expensive. not every station is in HD, but those that are are very clear and sound nice over my alpine speakers.
granted it is aftermarket, but i have a screen and it is Nav. capable as well as back-up camera ready, with HD radio, ipod/"anything-with-a-headphone-jack" connectivity, and its even XM capable if you want to go that route as well.
i'm only using the ipod interface and HD radio at the moment, but the camera is soon to come. i dont plan on using the nav. or xm features.
i can get pics tmrw if you would like, but the install wont be 100% complete until i get my custom head unit mount, which looks and fits 500x better than what i have in it now.
hell it looks the exact same as my old one i'll just post pics of that
the only difference in appearance is that the new one says HD radio on the front
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
