Eury Jr. Out As Crew Chief
gave20
We'll now see if it was a bad driver or bad crew chief screwing things up on the 88 team. I'm leaning towards the bad driver.
no more excuses
They've both screwed up way too much since he moved over to Hendrick. But hopefully the new crew chief can get things in order.
I'm not sure, but now there will be no one to blame but the driver. Eury seemed to make some questionable pit box calls, but Dale does like to miss his pit stall too. We will see.
im a huge 88 fan and its about time they split the two up......now with a new crew chief and the best equipment the series has, JR better improve.....if not I will finally be able to admit that its the driver
+1....I hope this helps Jr.,If not then.........Its the driver :lol:
I haven't liked Jr. since Sr. was still around. I remember being pretty young and watching Sr. destroy people on the track. That man could drive! I'd feel safe saying he's the reason I got into racing. ...Or maybe it's because I'm a redneck. Oh well!
/nostalgia
How many times has Jr. screwed up in the pits? DW said that he should just stay on the track and he'd be unbeatable. :lol:
That's hard to say, he could be to close to the wall, to the line whatever but he's missed his pit box 2 or 3 times this year.
I've watched the in-car coverage on DirecTV 2 or 3 times from Jr's car. There have been times that he'd be running GREAT, until a pit stop... Tony would call for a change and it'd screw the car up so bad, Jr could barely keep it out of the wall.
I, for one, am looking forward to see how he performs with someone who knows the ropes at Hendrick better and who communicates with the other teams better. That should improve the cars, which should improve his results.
Time will tell....
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
