Cylinder 6 Misfire, Po3o6 Code?
lltrevino
Engine Performance problem
1998 GMC Sierra V8 Four Wheel Drive grey_loader.gifAutomatic 130000 miles
I am @ my wits end. I have a dead hole in my 5.0 engine. I pull a p0306,cylinder 6 ,misfire. I have changed the cap,rotor and plugs, spider assembly, upper and lower intake gaskets, the cmp sensor, the Bank 1 sensor 2 O2 sensor, the bank 2 sensor 1 sensor, ECM, and a new fuel pump/module is on the way.
I have done some limited scans, and bank 2 fuel trims are rich, still, even after gasket change on lower intake. I did find #2 intake runner gasket was bad, along with front coolant port. I have done a vacuum test around 13# steady. Did compression test and running compression test, found nothing out of the ordinary. However fuel pressure immediately drops, when fuel pump stops running with key on engine off. I have traced the pump to be leaking(pinched both fuel lines, only than does pressure hold). Now i installed pump, it holds fuel pressure fine, but still a cylinder 6 misfire. However unsure why is only picking on bank 2 cylinder 6 especially. I pulled banks 2 plugs. all are black, EXCEPT CYLINDER 6???? Cylinder 6 is still whitish, with minimal black. This truck only has 1 coil, for all 8 cylinders, why is 6 a problem, when static, and running compression is still in range with all other cylinders?
This is a friend's truck, i did also find MAF sensor in backwards, I did clean it, install correctly. However also getting 8.4 g/s on scans. I am going nuts here, what am i overlooking??? newcode.jpg here is a freeze frame
Did you replace the spark plug wires?
Try these...
Fuel Injection Service, Not Just Cleaning...
http://www.asashop.org/autoinc/june98/techtotech.htm
Misfires...
http://www.random-misfire.com
Then if all else fails, get a GM factory Fuel and Emissions Service Manual for your year/model vehicle and follow the troubleshooting testing charts in that. Might want to get the full service manual set - 4 books.
Did you try an injector balance test??? Check pin grip(electrical connection at fuel meter body) on the injectors??? Is the injector pin terminal broken or bent from disconnecting/connecting the injector harness??? Open #6 plug wire?? I'd start with the above.
wire test on great, new wires were installed with a tune up to first correct issue. I have put a noid light on to check for injector firing, it is fine. owner had advised me to put a new ecm in(against my judgement), that was not a problem. last night i pulled plugs on bank 2. cylinder 6 plug indicated correct plug reading, while cylinder 2,4,8 all were dripping gas. this leaves me to believe, somehow, cylinder 6 is sucking LOTS OF AIR, while all the other plugs are all sucking normal air. what is going on?????
You say #6 is whitish? Like an ash on it? White ash is a contamination, either by coolant or possibly oil. You may have to reinstall your intake gasket or you might have to pull the head and inspect the head gasket.
When you replaced the intake gasket, did you check for warpage?
*just thought of another*
The cylinder temps could be too high. Are you using the correct heat range plugs?
Out of the clear blue today, the truck just magically cleared up??????? :fume: no clue how or why??? talk about confusion, could there be a sticky valve or lifter?
I meant 6 was white, due to nothing evening appear to be happening in the cylinder. It was white as no fuel entering, or the plug appearing to be ALMOST new like. I did put some fuel additive, it did have some small red spots, which I believe was the fuel additive. However all the 3 other cylinders in the bank, were excessively rich appearing.
    • Thanks for that, yes just because I could I measured what came out just to give me some guidance although I already knew to expect it to take at least 9.5 to just throwing in the whole 10 quarts off the shot and doing a one and done heat cycle to drop out the excess to get to the proper level. I don't recall exactly now what I measured that came out but was less than I put back in, I knew I spilled some on the garage floor but the main part was that I was thrilled in the discovery I did not have to touch my exhaust to flex it down. The gasket manipulating is a pain of course to create that clearance to take the pan out and put back in but its all very doable if one is careful and not forcing the gasket to flex too much. From the quote I got at a transmission shop of 900.00 here in Canada ( never asked at the dealer what they charge ) I saved 700.00 doing it myself after paying for the supplies so that to me paid very good wages !, and I knew what fluid was put in and that I had changed the filter and that the level is correct without any doubts.
    • I do have one of the AFM diasable box, using it for last 1.5 years.
    • I found a setup that lets me open the cover partway with racks installed, using side-rail-mounted systems for easy access.
    • Typically its said and I agree so far that the engine oil drain plug oring is not required to be changed out unless you see some damage happening to the oring as apparently the oring lasts well. The dealer I have been getting a few parts from never even stocked the oring but instead stocked the whole drain plug that comes with a new oring which for the dealer is easier because they just throw in a new drain plug if there was any question about damage on it as well and charge the customer accordingly but again only if it is needed.    Also a hint about the drain plug oring to help it last vs a risk of causing damage to it, after its been removed and wiped off or washed off ( that is a whole other topic about some solvents damaging orings because some solvent types do ) to make sure to relube the oring with a bit of new oil so that it won't "grip" on the sealing surface of the pan and needlessly stress out the oring. Its no different than putting some oil on the sealing ring of the engine oil filter. So I just grabbed a new drain plug to have on hand although more recently bought just the oring as well but as its special it costs half the price of the drain plug ... !   Since you mentioned the hate to be empty handed theme, I am not sure what you have in the way of filter removal tools as I like using the exact sized for the filter steel 1" wide band with side to side swivel handle filter removal tool, and it can be used to snug up the filter without risk of damaging a filter as well ( its probably a lisle brand I have ). The drain plug hex size is 15mm and I always like using a 6 point socket if I have a choice and with this truck I've been using just a 3/8 ratchet that has a fairly long handle. Do you have a funnel that will work to pour oil in as that is definitely the short coming bastard part about the design with that fill port on the valve cover on such an angle that no normal funnel will even work. There are adapters and things on the market that will set into or screw into that fill port, I didn't want to deal with US shipping as that is all I was seeing at the time so caved and bought a Lisle brand multi vehicle fit adapter funnel kit and it really works well but there are much less expensive adapters out there that work in conjunction with an off the shelf funnel that would do the job also. Now that I have it, I like how it works and works so slick with the shape of the Amsoil 1 quart containers I have now switched over to. Whatever you do, have a funnel system of some sort as you will be swearing if you dropped the oil and then realize you have nothing to properly pour new oil in without spilling it all over the engine !.     Other comments, quite a bit of oil flows out down the filter when its cracked loose due to the housing above the filter so let it dribble down the filter until it slacks off flow and then remove the filter to create less possible mess. It seems these engines can sit for quite a while and drip and if you have time let it sit there and drip out of the engine as much as it wants. Also a good time to grease the 9 zerks on the front end, that's my typical practice anyway to grease the suspension and steering each time I change the oil. And remember to reset the oil change minder ( not something I am used to doing with older vehicles and equipment ).
    • I really did not measure what came out. I carefully followed directions to check level after i did the spill and fill and filter change. I used 10 quarts. 9 was not quite enough. My trans temp was about 175 when I checked it. Truck sitting in my driveway very close to level where I always check oil pretty much every time for consistency. My driveway is just ever so slightly downhill to run water to the street.
