454 Oil Pressure Loss
im looking to buy a truck with a fresh 454, not even broken in yet and im told that it has good oil pressure until it gets warm and then it looses oil pressure, he also said that when he took off the valve covers that oil barely came out of the top. just wondering what could cause this, and also if anyone would be able to tell me what it would cost me to get the problem fixed that would be great thanks
What kind of vehicle is this engine in? Was it properly primed? New crank? Did it run for a while before it had proper oil pressure?
Low oil pressure is one of three things.
The oil pump is not working or is faulty.
Bearings too much clearance.
Oil passages blocked due to sludge buildup
Either the engine want built correctly, or it wasnt hot tanked completely.
You don't say how old the engine is. But I have seen some that where the pickup goes into the pump it will come loose a little and suck air into the pump and not have good pressure. If it is cold and has good pressure but as it warms up the pressure goes down that could be the problem. On thing you might try and I will get flamed for this is on every BB I have every ran it had one or two extra quarts of oil in the oil pan. Try that oil is cheap and see what happens. If pressure stays up then you are pumping air.:fume:
Who rebuilt this "fresh" motor? Did they do a complete rebuild? Or maybe just half ass it? If it's having oil pressure problems now that's not a good sign. If you buy it, buy it cheap.
that oil pump pick-up is a good idea, since they are just a press in, most good engine builders will either brase them on or get a circle track style pick-up, and i would also guess that a clogged oil galley would not change with temp.
    CaptainDad
    CaptainDad
  • Who's Online   5 Members, 0 Anonymous, 487 Guests (See full list)
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
