Code Po449
Can someone tell me where or show a picture of the vent solenoid for me ? I think I can fix this myself if I knew what part(s) to change. Any other advice on the subject is appreciated.
Thanks,
Yotaman
Is this a dealer only part ?
I just changed mine out yesterday. On mine it is in front of the gas tank, in front of the canister. It was a dealer stock item. Auto Zone didn't carry it. Ended up costing $160 after tax. I also needed 6ft of 5/8 hose and 4 hose clamps. 1 ft to go from the canister to the solenoid, and 5ft to go from the solenoid to the filter that was included which is tied up near the tranny.
So far so good. CEL hasn't come back on.
But keep in mind, this is on my 07 NBS, so it may be slightly different for yours.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 1,020 Guests (See full list)
