No Oil Pressure
Now I know there is oil pressure because this issue has been happening sense last fall. when the truck warms up the oil gauge just stops working dash light comes on but if I had no oil pressure I figure it would have gone boom by now.
So my question is do I need a new sender or can I just take the old one off and clean it up and have it work like it was before?
(88' 5.0l TBI SBC)
I would buy a new sender,oil pressure is one of those things I monitor closely.Check the wiring if you haven't done it already.On my '95 if the gauge shows no oil pressure the ECM won't let it start...protects the engine I guess.Yours must be different?Maybe the gauge is bad but the sending unit is still good? dunno
Last year my engine all of a sudden died(while driving up a hill) and would not start,I replaced all kinds of shit without gettin it to start.Then,thanks to this forum I checked the wires going to the sending unit...sure enough,one of the wires had layed against the exhaust manifold,melted and grounded out.All I did was un-stick it,zip tied it back out of the way and VROOM,it started...
oil pressure sending unit will cost you no more than 20 bucks, it's well worth the replacement. +1 on checking the harness too, never a bad idea any time you replace an electronic item
Cheap that's what I like the hear with this truck being my winter beater. The 305 can blow up for all I care, it give me the motivation to get a 350 :lol:
Hell yes,and do a build thread :lol:
Is there any way to test the gauge to see if it's the gauge rather than the sending unit? My pressure, temp, and battery gauges aren't working right, but I don't know if it's the sending units or the gauges.
Basically this is somewhat complex. If you applied full voltage to the gauges to test them, this could damage them.
And these things have all sorts of different electrical designs. How the oil sending units work, how the gauges work, etc.
I think you would be safest to get a GM factory service manual set for your specific vehicle and follow the step by step instructions for troubleshooting this. This would give you warnings to not do something which could damage the gauges if that was a possibility.
Then various instrument gauge panels are ALL different! They change this stuff like night and day. In some cases the sensors would provide a ground or a varied resistance to ground to make the gauges operate. In other cases a positive voltage or varied positive. Or a mixture of both depending on the gauge.
So I couldn't tell you a general way to test your gauges over the internet and be safe to not damage the gauges.
Also for testing the oil sending unit, the factory books would tell you which wire to test, where to place the other wire of the multimeter (ground or positive or to another lead on the oil sending unit with plug disconnected and measure resistance), and would tell you what an acceptable reading would be. And might have you check for a short to ground.
The thing is there are many different designs out there for oil sending units. No telling what you have! (Without looking at the manual for your year vehicle.)
Basically I would say to get the factory books or have an electrical guru fix it.
You can check your fuses...
http://www.dinosaurelectronics.com/Test_Fuse.htm
Thanks for taking the time to write all that, I appreciate it. I'll check my fuses since I've got a meter. If that doesn't work out, I guess I'll try to acquire a book for my truck.
    • It is working as designed.  NHT and non NHT trucks have the same exact transmission cooling setup.  NHT just gets a larger radiator.     The transmission cooler loop on these is as follows.     -Transmission out goes into an oil to water heat exchanger (item #1 in the first illustration below).  This exchanger has engine coolant opposite the transmission fluid and uses engine coolant to warm and then regulate the transmission fluid temperature when its in the operating window.   - From the cooler it goes to a thermal bypass valve (item #11 in the 2nd illustration below).  If the ATF has not reached the temp to open the bypass (194F), it loops back.   - When it reaches 194F, the thermostat opens and ATF then flows out to the oil to air auxiliary cooler (item #17 in the 2nd illustration) at the front of the truck.  From there it goes back to the transmission.     Your only fix would be to swap for the PPE thermal bypass delete block which will open the loop to the aux cooler all the time.  It will STILL run warm, probably 170-200F, but that's as low as you'll get it as its still flowing through the oil to water exchanger.
    • Most say the oil temperature needs to above the boiling point of water to rid it of moisture and long enough to dry it. Many think that is about a hour at 212 F or more. Those people have never line dried cloths in a Midwest winter. Leave a pan of water sitting on the counter and eventually it all evaporates. So heat drives the time it takes. Water in oil under 175 F, the Nitration initiation temperature, is a minimum then for temperature and samples I've done that use Karl Fisher method say about a hour (in a healthy well tuned motor) over 175 F will dry it to under 800 ppm. Low enough to not be much of a factor. Motors with weak rings will take longer and the colder the air temperature the longer it takes.   On a cold motor there is also the condensation temperature. Blowby gases that contain moisture are subject to that cold cylinder wall, like sweat on a glass of ice tea. But also subject to the Law of Partial Pressures. Wear studies by GM and the DOD  indicate wear is a real issue below 85 F and a concern to 140 F but doesn't become a minimal factor until about 160 F. You know this intuitively when you see water vapor exit the exhaust pipe until the system gets above the dew point. It isn't magic, it's physics and it fascinates me. I know you didn't ask but....I over share sometimes. 😉    You keep the Camaro's high and tight.
    • Move further away.   Benefit of living out - none of our cars get short cycled, plenty of warm up time.   Curious how much time/temperature it takes to drive moisture/condensation out of the engine?
    • Switch a a 100% synthetic trans fluid, Amsoil works for me.
    • First of all sorry, I know there are a ton of transmission temperature threads...   My truck is a 2025 LZ0 High (10l89 10-speed) High Country with NHT max trailering package. The NHT package is supposed to have "enhanced cooling."   Normally the trans temp sits around 200. It seems like with any real stress it quickly jumps into the 220s (for example climbing a grade unloaded at lower speeds). I haven't towed much with this truck, but I'm concerned if it gets this hot unloaded.    I've tried a few different things to keep the temps down (tow/haul mode, sport mode, low range when that makes sense) and nothing seems to affect it.    I'm curious if others are the same behavior or if anyone has found techniques to keep the temps down. It seems like it just can't handle reduced airflow at lower speeds, even with relatively light loading.    Thanks!
