New Truck A Couple Questions
Just bought a new 08 GMC 3500 D/A Dually.
1st. Does anybody have the GM hood protector, and if so, what do you think about it, and can you post a picture.
2nd. I have just the single button to access the trip meter and oil life monitor and things. In the Accessory Catolog there is a Driver Information Center that goes in the dash to the left of the steering wheel. The catolog states it will give me more features. Is that true, and is it plug and play or need programed.
Thanks for any help.
Mark.
I am looking for a bug shield or something like that as well. I have been considering installing some 3M clear bra on the leading edge of the hood and fenders along with the head lights.
AS far as the DIC, from what I have read here and else where, it is a plug and play. The harness should be there. Then all the information can be cycled thru by using the 4 buttons on the DIC.
My truck came from the factory with the DIC and it does come in handy.
Mark.
Mark.
Probably going to get both from GM.
Mark
Mark.
The DIC is plug and play. You need the switch and the plastic plate (the wiring harness is already behind the blank plate that you have now).
The DIC is a simple parts switch = parts about $100.00
well worth the effort do not let the dealer tell you they have to install you can do it.
I have the chrome gm bug screen and I love it. You may have to seal the edges of the windshield gasket to the glass, I did otherwise you will get this flapping noise at highway speeds. Sounds like bb's hitting the windshield, now no noise at all.
Me and the wife installed the bug screen in about 45 mins start to finish. It will be easy to do with 2 persons.
Thanks for the replys.
Bought both from GM. Got the bug screen on but been gone for a week, so don't have the DIC on yet.
Took my first trip with the camper and the new truck. Wow what a difference. I was never really unhappy with my 00 2500 6.0 gasser, but this new D/A dually beats it in virtually every way.
Mark.
    • Most thermostatically controlled ATF systems use a 'wax' pill just like the one in your water thermostat. They work on the expansion volume of the wax and the pill is constructed in such a way as to limit the travel to remain within that range. This means it has an opening temperature often called the 'cracking temperature' and a fully open temperature. For whatever reason oil is designated by it's fully open temperature and water by it's cracking temperature.    Between the two it the "Regulating Temperature" The entire range is about 20 F from closed to open. In your example the lower limit, opening point of 145 F then has a fully open temp of 165 F and a throttling temperature of 155 F.    Thing is, the throttling temperature needs two things to work properly. Enough system load high enough to reach the minimum and a heat sink (cooler/exchanger) large enough to prevent any load applied from exceeding the fully open temperature.    If your system exceeds the fully open temperature it is screaming MORE COOLER.    Here is the silly part of the whole thermostat system where the oil is cooled/heated by the radiator. Nothing is flowing to that system until the oil temperature reaches the cracking temperature unless it is equipped with a minimum flow bypass orifice or a bypass built into the seating surface of the plunger. That system meant to get it up to temp quicker isn't doing a thing until WORK drives if from ambient to cracking temp. One a cold winter day, like zero F, it may never get hotter than about 110 F. Sometimes not even that.    People forget or are young enough to not know that until this millennia transmissions were cooled by the radiator cold tank alone and without a thermostat at all.  In the 50's they weren't even cooled. OEMs learn everything the hard way.    When an OEM tells you the trans "Works best" between 175 F and 220 F it means works best for THEM. The transmission thermostat is fuel play. If you watch you trans temps like I do you will learn that it may take a hundred miles if you are not towing and not driving more than say 55-60 mph on a zero F day to even reach 120 F and it might sit there all day if it's colder. Yet if functions perfectly over about 100 F. It may need to get a bit warmer for the fuel and spark maps to go without an multiplier.    Worry more about too hot. Use a cooler large enough to put that thermostat in range.
    • Around 2008 if memory serves they took sulfur out. That was when diesel went up.
    • Question for you Grumpy, why is diesel so much more than gasoline? Seems to me that it may be slightly a little less refined than gas and it doesn't have 10% alcohol which presumably lowers the price of gas
    • Thanks, so being a different beast altogether, anyone know what the "optimal" temp is for the 10L80/90 for proper shifting?
    • How many years have I pointed out every point in that link to the folks here and been avalanched with criticisms and outright hostilities at times? I ran counter to even the great CUSTOMBOSS and Lake Speed Jr and the half dozen experts on YouTube and in the final.....GM, Physics (Stribeck) backs that Grumpy old Bear.    Honestly, I never said a thing engineering hadn't studied silly and laid in concrete during WWII. But I'm old, the information is old and yet, the Laws of Physics are eternal.    Okay there is one exception. I vehemently disagree with their use of the word 'tolerances' when what it meant is "clearance".   The clearance is the distance between two objects. The tolerance is the degree of acceptable variation permitted in that clearance. I.E., piston to bore clearance is 0.004" with a tolerance of +/- .0002" so the clearance is in specification if it lies between 0.0038" and 0.0042". Cutting that 'tolerance in half has ZERO impact on lubrication requirements. Makes for more difficulty in manufacturing.  But a tighter clearance 'MAY'. Depends on finish. Anyway....   It's one of those statements made by people to make themselves look smarter than they are to convince people who are as un-enlighten as they seem to manipulate their behaviors. But hey, the blind leading the blind puts them both in the pit.
