'96 Silverado Misfires
First time poster...recently bought 96 5.7L Silverado 120k miles. Suffice it to say the seller was not an honest man and/or I am too trusting...
Day after I bought it got 2 codes:
1)P1345 crank/cam relationship error.
2)P???? left pre-cat O2 sensor low voltage.
What I did:
1) I cleared the codes with the OBD reader. I've never seen an 02 sensor code again.
2) P1345 came back same day
3) Took truck to shop, they used scanner and found ignition set 17 degrees out (should be 0 +/-2 degrees)
4) Shop pulled the distributor, found it off by one tooth, re-installed. Gear looked "GREAT"
5) No more P1345 or ANY error codes of any sort (I've since put 1700 miles on the truck)
Problem:
Still with an occasional misfire. Most reproducible when coming over the top of a high hill, occasionally a hiccup while going up a hill. Driving around town, very rarely any misfire.
What I've done:
Put a tank full of 93 octane fuel--didn't really help
Put a pint of Seafoam in tank with ~8gallons gas in tank--wallet is lighter, no other change
Bought a Scanguage to monitor the engine a little better
What I can tell:
-The plugs are new, gapped well, clean.
-Wires are very new appearing
-Cap/rotor looked new per shop (seller said was recently replaced)
-***Scangauge shows IGN of "-2.2" at 1200RPM, goes to as much as "-3.3" under load. I don't know if these numbers are advance or retard (and accordingly what + and - mean before the numbers). Amongst other things, I really don't have a grasp on this Vortec ignition system...
-If I keep the LOD (load in scangauge) below 25%, it never misfires.
Questions/Comments:
1) I suspect that the distributor is still out of spec, but I don't know what the Scangauge is telling me.
2) In researching this type of problem can be caused by any number of things (bad plug, wire, cap, rotor, cam sensor, crank sensor, vacuum leak, intake gasket leak, bad O2 sensor, bad ground, bad TPS, bad cat, carbon buildup wherever....)
3) I'm trying to approach things methodically rather than replacing everything that will unbolt
4) Again, most reproducible misfire occurs at the top of the hill, when coming out of the throttle (worse with cruise control on)
Any ideas? Thanks in advance.
That's right, all sorts of things can cause this! Try here...
http://www.random-misfire.com
Then oxygen sensors should be replaced as a regular maintenance item every 60,000 miles. This will also give you better gas mileage.
And so far as saving money (no guess and replace), best to get a GM factory service manual set for your year/model vehicle. These are 3 or 4 book sets. Then you can test various things. If they are per factory specs, then no need to replace!
Also these books have driveability symptoms, a list of things to check for each symptom, how to test, and what the test results should be.
For testing you would mostly use a multimeter and a fuel pressure gauge - sometimes an exhaust pressure gauge.
Here is on testing your fuel system...
http://www.asashop.org/autoinc/june98/techtotech.htm
Thanks for the links.
I replaced the cap, rotor, wires, spark plugs. A little hesitation accelerating from idle was present before, now gone. Still having the hiccups on the highway.
I can't get over that the ignition is so 'retarded.' Starts -10 or so, gets worse with increased load. I don't think that the engine is all that rough, meaning so as to engage the knock sensor etc. My daily driver is an old diesel Mercedes so maybe I'm not in tune myself.
I am wondering if the the base timing wasn't set up correctly the first time.
Also considering pulling the plug on the knock sensor for a few minutes to see if ignition numbers improve on Scangauge.
Also will check the fuel trims tomorrow as I've read you can use these to get a sense if there is a vacuum leak.
Thanks for the help.
Basically there are electrical sensors which input information to the engine computer. Sensors which would monitor the following things would cause the engine computer to change the timing based on their input...
Crankshaft position
Engine speed (RPM)
Engine load (manifold pressure or vacuum)
Atmospheric (barometric) pressure
Engine coolant temperature
If one of the sensors monitoring the above was reading wrong or the wiring to one of these sensors had an open, short, or poor connection, then this could cause the timing to not be as it should.
I would check those before checking the base timing.
This morning I tried to assess the knock retard with Scangauge, apparently this function isn't possible for my truck.
Maybe on to something else here....
I programmed the scangauge to monitor the short and long term fuel trims for Bank 1 and Bank 2. Values are as follows:
SFT1: -97
LFT1: 0
SFT2: -2
LFT2L 0
Seems like bank 1 is really getting the fuel dumped in. These values don't seem to suggest a vacuum leak.
Will keep looking along this fuel trim path for now.
I interpret from the fuel trim data that, at least, Bank 1 is getting extra fuel somehow.
Recall that I mentioned getting an error code for the right pre-cat O2 sensor a couple weeks ago. I cleared it and it never came back. The O2 sensors are probably original all around.
So today I've now replaced the Bank 1 (left) pre-cat O2 sensor. Still getting the same driving problems. Fuel trim still shows that the computer is trying it's hardest to lean Bank 1.
I don't know if this fuel issue in Bank 1 is causing all my problems, but it's where I will continue to concentrate.
If the problem is limited to Bank 1, I assume that this would exclude a lot of issues (EGR, TPS, MAS, coollant temp) that should be causing mixture problems in both Banks. At any rate, seems like I should start to think about an injector problem. I assume this is something a shop needs to look at? I could have them check base timing same time.
Thanks again for the help/interest in my problem.
I think you are on the right track.
I would be checking injectors next.
And the timing. That does not seem quite right.
There should be more advance than what you are getting.
Didn't the 96-98 have problems more related to the fuel regulator as well? Sorry, I am still working with the simpler TBI set-up on my old truck...
--Mike
With my ScanGage attached, I routinely show -20 to -30 on my timing while driving and the truck runs fine. (96 5.7L). I was told on one of the truck forums not to pay much attention to the readout due to the electronic timing. But I would think the technicians would know this as well, so I may have been given bad info. But I don't get any knock or dieseling, and I get normal (15-17 mpg) fuel economy. It does prefer slightly higher octane for better economy, but I don't get any pinging on 87 octane.
    250.3k
    RobbertClaus
    RobbertClaus
  • Who's Online   5 Members, 0 Anonymous, 508 Guests (See full list)
    • No I didn’t watch a video of a person who analyzes oil for a living explain general oil usage. For clarity I did ask my brothers one who runs our equipment business. The other who runs our old ROW business about oil usage. Nothing has changed since I retired. Their personal vehicles or work vehicles use no oil. Not enough to see on the oil checking device. Then I pondered. I like to ponder. In this extended oil changing world with oil change countdowns or lights. If engines used say a qt every 2500 miles or up to even 4000 miles. With oil changes reaching as high as 15000 miles. Normal for most people is eight to ten. Vehicles should potentially be seizing up all over the place. Especially in hilly terrain. Just how many people actually check their oil? Maybe 10 percent. Those are the people that probably change their oil early. I like to research used car listings. I have five favorite dealers I check. They all list carfax with their listing. It’s rare to see vehicles with anything but extended oil changes. Transmission service, forget about it. I’ve seen Honda and Toyota certified vehicles up to 100K miles and ten years old. With nothing but normal maintenance. Isn’t nice we all have different experiences and believe our way is the best. You certainly get backup for whatever you believe. Life would be boring otherwise.
    • Interesting rumor. Dealers near me have been tight-lipped so far, but if this reveal actually happens next week, I'm really hoping they finally give the HD a proper interior overhaul. The competition has been eating their lunch in the cabin department for a while now.
    • There are a few good takeaways in that video that pertain to this thread, certainly the possibility of the oil control rings having buildup, the fuel injectors and how clean or not that they are ending up affecting the pistons rings carbon buildup, and the fact that its normal up to a point for a given engine to use some oil, and that the oil quality that is being utilized is part of that ring clogging up issue as well.   I was talking with a neighbor yesterday who has a baby LZ0 duramax and he had bought it slightly used but it does consume some oil and he has switched over to 5W-30 Euro spec oil and in this case that never made a difference in consumption over the factory 0W-20 recommendation. He finds it uses a quart in about 3500 miles and as he goes a ways over that distance he adds oil to full and goes another 1000 miles or so and then changes oil and is typically at 40% or so left on the oil monitor at that point with his use case of quite a lot of highway miles and more limited in short run use. I don't know what other LZ0 engines are doing for oil consumption but that is what his is doing.
    • I dont care what Lake says. Goodnight.
    • Ok well I guess Lake disagrees with me on a few points. I call oil consumption pretty basic. Rudimentary. He calls it "really complicated." I think 1qt consumed in 3k miles is a lot. He says that's normal. In 22 minutes, he'll use his natural talent to explain oil consumption to anyone watching this video. He covers everything from obvious engine damage to how normally functioning healthy engines consume oil by design. Lake explicitly states how you drive will impact oil consumption.   Shut up and watch:
