4.3 Not Accelerating Normal
I have a '99 round body style silverado 1500 it has the 4.3 v6 with the 5spd manual transmission. Recently it started to stumble when I pushed the gas pedal down too far. This was after a 500mile trip not right after I got home but I'd say a week or so. I checked the plugs and they all seemed to be fine and I had replaced them not too long ago along with the oil. So I changed the distributor cap and rotor hoping that it would help but it didn't. (although they looked bad) The only other things I could think may be wrong is the EGR Valve and or The catalytic converters. I did get a code once of random misfire then I cleared it with my hypertech and it hasn't come back. It just isn't accelerating normal at all and runs rough when I give it more than say 1/4 throttle, so I just take off real slow. Any help I'd appreciate and I will try to fix it on friday in my driveway after I get paid.
thanks
Matt
Common things to check/clean or replace
Wires, plugs..
Fuel filter, air filter
PVC
Clean MAF sensor and intake
After that, If still no change, I'd look a little deeper.
thanks
Matt
This is a TBI system. I would check those two fuel injectors on the carburetor. With the truck running/idling, air ducting removed, you should be able to look at the stream coming from the injectors. You should see a fine mist throughout a throttle up and down. If you see any dripping, you either have partially clogged injectors or low fuel pressure due to an obstructed fuel filter or weak fuel pump. I would check things in that order. You can remove the injectors fairly easy and take them apart and clean them with a carburetor cleaner. I would then replace the fuel filter for good measure.
Good luck and let us know what you find!
I've replaced the wires about 45,000 miles ago. THey look perfectly fine but how long you guys think those should last. The air filter is clean its a specrte reusable. I'll probably go with your advise draenor and stevens07 replace the fuel filter and pcv valve. Oh Adber it's the round body style that has multiport or whatever, but I did have the tbi in my last s-10 pickup. Hopefully that will do the trick. I hate having to lay off the gas pedal ha ha.
Thanks for your advice everyone
I've replaced the wires about 45,000 miles ago. THey look perfectly fine but how long you guys think those should last. The air filter is clean its a specrte reusable. I'll probably go with your advise draenor and stevens07 replace the fuel filter and pvc. Oh Adber it's the round body style that has multiport or whatever, but I did have the tbi in my last s-10 pickup. Hopefully that will do the trick. I hate having to lay off the gas pedal ha ha.
From what you mean by "round body" you mean the GMT800 body style from 99-07?
thanks
Matt
If I am understanding this right...it runs OK, if you are not CROWDING it, by giving it more than 1/4 throttle.
Anytime you try to hurry a little...that is when it runs bad.
After you do the easy stuff and it don't help...have the converter checked.
There is a gauge they can install in the exhaust pipe, JUST IN FRONT OF the converter to measure back pressure.
Thats what I am guessing it is. The converter.
It's a round chevrolet silverado 1500 model, check the picture i've got up. Thanks texas jim, I was thinking of seeing if I could unbolt the cats but a test at a qualified shop would be much better. I installed a new fuel filter and pcv valve and it does run much better but at times it will still hesitate so I will look deeper as you said stevens07. I may just buy a new egr valve if the cats clear the test. Hopefully it isn't much more that a need to fix. Thanks for your help everyone
hey guys I was just wondering if my truck has a cat coming from each header, can I put a single cat instead of the two that are on it?
On the cats no. You need to have each side of the motor monitored by the computer. It takes feedback from each side, upstream an downstream.
Oh ok I was hoping there was an easy way out.
    250.3k
    user087
    user087
  • Who's Online   3 Members, 0 Anonymous, 854 Guests (See full list)
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
    • So after reading the reveal from Chevrolet, I kept asking myself...why did the trim levels change?   Here are the official ones:   Work Truck (WT): The quintessential fleet truck, built with durable, easy-to-clean interiors for commercial or utilitarian use. Custom: A stylish, road-oriented trim that adds a more refined appearance, standard dual exhaust, and modern exterior styling. Custom Trail Boss: An entry-level off-roader featuring a 2-inch factory suspension lift and 34-inch mud-terrain tires on a budget. Silverado: Serving as the new base consumer truck (replacing the previous LT trim), it comes standard with the Z71 off-road package when equipped with 4WD. Trail Boss: Steps up the off-road hardware with the 2-inch lift, 34-inch tires, monotube shocks, an exclusive off-road hood, and more premium interior options. ZR2: The flagship off-roader. It boasts 35-inch mud-terrain tires, Multimatic DSSV dampers, front and rear electronic lockers, forged carbon-fiber interior accents, and an available hardcore Bison Edition (co-developed with AEV). High Country: The pinnacle of luxury. It replaces bright chrome with modern satin chrome, 22-inch wheels, premium leather, real wood interior trim, a panoramic sunroof, and an exclusive front-passenger touchscreen. As others have stated, why would you want a Silverado - 'Silverado' - wth?? LT needs to remain!!!   Also, there will no longer be a dedicated Z71 model.  All 4x4 trucks will have the Z71 package. Carplay is also something that cannot be removed.  Hopefully it will remain.     I am excited about the 5.7L V8 (350 C.I.D.)  Old school Chevy power.  My only concern is whatever version of AFM/DFM cylinder deactivation.  Too bad that isn't an option a buyer can choose to have or not.   I will definitely be stopping by my local dealership when these trucks start showing up.
    • I haven't seen diesel for less than $5.30 anywhere in my area
