2000 Silverado 1500 Lifespan
What is the typical lifespan of a Silverado with the 5.3L V8? As of now the truck has 156000 KM, is there any point in putting some money into it? if so where would you direct your attention to?
It should have plenty of life left in it, that is if it was taken care of. That is the question. The engine if properly maintained should last 400,000KM or more. So you need to find out the maintenance records.
I would change the front/rear diff fluid, tranny fluid, transaxle fluid/filter, shocks, plugs, wires, PCV valve, cabin air filter, fuel filter, air filter. Check your brake pads, and flush the brake fluid.
Lube the front end and clean the MAF sensor and intake body.
That should be a great 100k mile tune up. Your truck should last you quite a while. I have the same truck and bought it with 92 k miles. I did all of this at 100k and it was a good thing. I also had to service the AC and change the U-joints, but YMMV.
You can spend some money on it to keep it running for a lot of years so far... Change most of the fluids (it is due for a transmission fluid change) then change the brakes, put synthetic oil in it and also take a look for parts that could be changed on the motor or near of it (whatever that touch the ignition). If you have a 4X4, change the differential fluid too for optimal performance and longevity of parts.
A truck like this can stay in service at least 400k.
Stupid question....being a canuck are you guys saying that if properly taken care of it could last up to 400000 KM or 400000 MILES?
What are the advantages of synthetic over conventional oil? I follow my km rating on my Mr. Lube sticker and get it changed at those regular intervals
here are acouple sites to explain it a little
http://www.minitruckinweb.com/tech/engine/..._oil/index.html
http://www.carcraft.com/techarticles/synth..._oil/index.html
i work at a shop here in canada and were still old school there we recommend chaging regualr oil every 5000 km and syntheic every 8000km. but in my mind the more oil changes you do the better. These new car with there oil life things are junk in my opinion i have seen a pontiac torrent that still had 10% left on the oil life when it had the oil changed 24000km ago. You cant tell me that motor will last as long as mine that is changed every 5000km. (not only that but my vortec motor will out last a 3400 motor if i never ever changed the motor lol) just my opinion
Yeah, they last a long time. If you want a daily pounder they're good for it. They just have lots of little annoying things that start to happen after a while. Same with every older vehicle I guess. I'm personally sick of mine and don't want to spend any money on it other than to keep it running. I want a new truck lol.
What sort of other little annoying things are going wrong? I just replaced my ignition cylinder this weekend
4x4 dash switch, in-tank fuel sender acting up causing the fuel light to constantly say empty, lost #1 fan speed setting on the dash, speakers now sound terrible and need replacing, tailgate needs the shit slammed out of it to close properly, rear diff cover is rusting/flaking off and needs to be replaced. Those are some of the most annoying things. But, my biggest peeve is there is a broken piece of something caught inside the dash near the vacuum doors/firewall. when I accelerate it sounds like a leaf blowing around in my dash. :(
Truck runs fine though, and really has minimal rust for how old it is. shifts great thanks to my black bear tune.
Scott,
My personal 99 2500 GMC Sierra has about 215,000 miles on it. All of which I put on it myself. It's had Mobil 1 in the engine and changed about every 4000 miles on average. Being in Southern California, it doesn't have any rust issues with the chassis or body. At about 135,000 miles I had to replace a front hub bearing and just went ahead and replaced both. I've put a lot of work into it lately for chassis stuff like the front steering rebuild and front suspension, rotating engine accessories like the water pump, A/C compressor, idlers and tensioners, etc.. Also, the transfer case and front differential were rebuilt recently. So, yes, I'd say you can expect a good deal of utility out of your truck, assuming it's in pretty decent shape.
Keep the oil changed regularly, same with trans fluid (if automatic), transfer case oil (if 4x4), and change the coolant (flush), and assuming it wasn't wounded before you got it, it should keep going for many more miles. Bottom line, the advantage of synthetic oil over conventional is lower wear rate. If there is a fuel economy advantage, I haven't seen it nor would I expect it would offset the added cost of the synthetic oil.
    • New member here, very long time occasional guest. Saw this thread, thought it would be a good time to contribute someting. It is only my experience and not a claim that everyone will have the same.   I bought my '20 3500 L5P new and have put 99.9% (literally) of it's current ~400k miles on it myself, with over 50% of that towing loads between 4k to 15k, and to me this truck has been nothing short of amazing. For the first 235k I had zero issues, and from there until 321k I replaced a NOx sensor, two failing glow plugs, and three of the notorious injector connectors. I believe this truck is in part, a testament to good luck, but also good care and following a decent maintenance schedule (I also keep meticulous records.) As a result, it looks as good as a well cared for 70k rig, up and down, inside and out.   At some point before that 321k mile mark I began to get a little spooked about the 10L1000, especially the valve body. Word of mouth about potential issues prompted me to jump on the net to sift through all the noise and determine what all the fuss was about. I routinely take long trips, coast-to-coast and points in between, so roadside breakdowns can be '...a thousand miles from nowhere' and a bit of a challenge, and though I had no issues, my guard was up and activated.   And then I stumbled across a chance to salvage some parts off a new 2025 that had been wrecked in transport. I grabbed a few wear items (alternator, pulleys, etc.) and on a whim asked what the ten speeder would cost me. It was cheap...really cheap. I knew some changes had been made in the '24+ version 10L and were supposedly not compatible, but I called service/parts at my local Chevy dealer and asked why and they didn't know. A call to a well known aftermarket transmission outfit revealed it was very likely it would be fine, but to them not 100% sure.   Because it was cheap (really cheap) and I was spooked, I took the chance. Had it installed by a local shop and it worked like a champ, shifted just like the original. At it's first service at 37k, I had the shop put in a Next Gen valve body kit, which after some initial hiccups and rough shifts, smoothed out though with somewhat firmer shifting.   All that said, I have a very serious concern about my newer transmission as just two weeks ago it suddenly began to exhibit a strong reluctance to engage forward or reverse. It was a bit past due anyway so I took it in for service. The reason it was sticking was due to 'glitter' in the fluid clogging the filter...not good folks, often indicates a converter giving out. We ended up going ahead with the new filter and fluid, first to see if it would move and shift, and then if so buy me a little time. It did, and I've driven it over a thousand miles and it is shifting smooth, no noises or slipping. Regardless, it looks like a third gearbox is in my future so I can resume taking long trips with some confidence. In the very short term, my curiosity will have me examining the fluid to check how much glitter has reappeared.   An earlier poster had alleged, in the context of 10L100 failures, that it is another example of how we seasoned citizens somehow descend into hysteria, lose control of our senses, and react irrationally after brief encounters with the idiocy of the internet infosphere. Let me say (and I have used and abused said internet since it's infancy) there is no segment of the populace that has a corner on over-reaction to digital garbage. Just as my offering of experience in this arena is purely anecdotal and should not be considered gospel or all-encompassing, I believe it is still worthwhile information to consider, along with other relevant anecdotal experiences about things like complex transmissions, especially when balanced with other sources.   So to answer the original question, yes I got high miles out of my first 10L, trouble free for 321,000. Now I really wonder how much longer it would have went. Did I 'overreact' to the internet ghouls by replacing a 'good' one with a 'bad' one? Maybe. Who knows, the thing might have taken a puke a 100 miles later. So I'll just fix it again, then move on and start thinking about all the other stuff that will eventually wear out. It still has the original brakes (they're at ~60%), original injectors/pump, turbo, water pump, etc....pretty much original everything. Knock on wood.
    • PCM?  These don't have a "PCM".  Powertrain Control Module.  They have an ECM (Engine Control Module) and TCM (Transmission Control Module).   Do you mean update the radio?     You can check what version you have in the settings page.  Should be Y181 but there might be a newer build they can update it to.
