*lag* Shifting From 2nd To Drive
I just bought an 81 GMC off my old man :P .. it has a rebuilt 305 with only 40k on the engine which is a bonous .. i've been driving it to find the little bugs and taking it really easy as it's been sitting for a few years.. i've changed all the fluids and also put in the *winter line stuff* into my gas..
i haven't had a change to change the auto tranny fluid yet.. and a few days ago i decided to open it up a bit and tromped on it.. and everything was good till it tried to shift from 2nd to drive.. x.x it *hesitated* 3 times before going into drive..
the guy who rebuilt the engine/tranny belives it is a 350thm with a shift kit in it.. i've been searching around for information but nothing .. hope someone here can help :( ..
PS.. could someone explain to me what a shift kit is for?? is it beefier gears in the tranny??
PPS pic before i got my new tires and seat
I just bought an 81 GMC off my old man :thumbs: .. it has a rebuilt 305 with only 40k on the engine which is a bonous .. i've been driving it to find the little bugs and taking it really easy as it's been sitting for a few years.. i've changed all the fluids and also put in the *winter line stuff* into my gas..
the guy who rebuilt the engine/tranny belives it is a 350thm with a shift kit in it.. i've been searching around for information but nothing .. hope someone here can help :smash: ..
Well, your transmission rebuilt and with a shift kit. You'll have a few things to discover about that shift kit. That shift kit is basically a re-routing of transmission fluid. It changes the shifting points and increases fluid pressure at some point. Depending on what option was chosen, which could be options like, track/strip or street/stock. Sounds like you have the track/drag strip mode where it is giving you higher rpm shift points making it shift hard. What parts are in a shift kit are usually just plates, valve body springs, balls, and gaskets. Something you can get for less than $50 that doesn't need a mechanic to install but, is a good idea. You need to have the correct engine configuration to take advantage of the track/strip option, primarily your manifold vacuum.
Hope this helps! I left a bunch out I think but, that's the gist of it!
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
