Leather Seat Reapir.
I have what appears to be a small tear in my drivers leather seat, basically on the drivers seat, left side. Can it be fixed with out taking it out and going to a pro??
What can be used??
  • 1 month later...
What can be used??
interesting that nobody is touching this topic....i'm curious as well. don't need it now, but the driver's seat in the 02 has some of the "wear cracks" faintly appearing, and the resulting tear is next, not sure how long that will take to emerge. I know the passenger seat in this truck had been removed and reupholstered while it was in the used car dealer's possession prior to my purchasing it, but no telling how much it costed them to have that done by an outside pro...surely less than you and I would pay "retail" to get the same thing done. Whatever the case may be, I can tell you that the leather they used is identical to factory, which leads me to believe that the material, in that color, is available, but I have no info on where an average joe would buy it from. I have tried (on a previous vehicle) the "leather repair kit" avaliable at auto parts stores and it is definitely a sanford-and-son-looking repair when you're done. If you just don't want a "rip" there, it will fix that, but it is visible when you're done, or at least it was when I did it. I know that is not much for specific information, but hopefully it will provide something helpful...
Mine already has the rip started and I can see the seat stuffing :thumbs: I have no clue if this can be repaired or if it's going to need recovered
Chances are, no repair will look normal since there is no way to put the leather back together without some sort of fasteners or sewing. Any good upholstry shop should be able to match the color just fine if you go the recover route. If the tear is small, they may be able to sew it back together without it looking "too" bad.
    • Mine worked fine until I got an update also. After that sometimes it would not connect and Id have to turn CarPlay off and then back on for it to try to connect again. I think I have had two additional updates since this started and it has gotten better but still not perfect.
    • It’s probably water in the doors. Mine had tape over the drain holes! Poked them open and that took care of it. Now I’m waiting for the rust to come through!🤬
    • Hi all,   I just bought a 2021 suburban RST with 88,000 miles on it and everything has been good but I’ve been noticing within the last month or so that there are small electrical things going on and I know what the AGM batteries and all the electric electrical in these big trucks you need to have a constant flow with good voltage   That being said, I bought a new battery thinking that that might have something to do with it but today I went to get in and start it and it said no key found when I had the key right in my pocket   It also proceeded to flash the lights inside and outside for over 30 minutes as I went to disconnect the battery as soon as I touch the negative terminal, I heard the relay reset and everything come back up. I got in the truck and started it no problem.   Anyone else have this happen to them? I’m starting to think it’s the KARR system that the dealer installed short circuit stuff.
    • I don't drive this truck on a regular basis since I have a new company truck with no out of pocket fuel or maintenance cost. Yesterday I got it out to run some errands and got the title message on my DCI. A quick Google search suggested to first clean the Map Sensor. I pulled it out and it was sooty so cleaned it up and reinstalled it. Issue not resolved. My OBDII is a couple years old so didn't see any codes. Today I took it to a friend at AutoZone to get him to check it with his reader. It had the following codes: P20C3 P02BB P221F Stating the most likely solution is to replace diesel emission fluid (DEF) tank assembly.   So, I guess a trip to the dealer is necessary. I read where there was a backorder on these tank assemblies several years ago so hope that has been resolved.
    • Are you using a weight distribution hitch system with your trailer as that alone can change the actual tire pressure requirements needed. It would prove interesting to see what the actual individual axle weights are on your truck when you are hooked up to the trailer. In fact when your hooked to the trailer, typically if anything unless it has a large capacity weight distribution system that is over cranked, often the weight on the front axle will be less when hooked up vs driving empty and certainly if one doesn't have a weight distribution hitch. Really the only times one may get up there with weight on the steer axle is if there was a snow plow mounted on the front or a motorcycle on a rack or with a very large jockey tank full of fuel at the front of the box that transfers a bit of its weight to the front axle.    And of course your tires carry more weight for a given tire pressure due to their size vs a stock sized tire so there is that to take into the equation as well.
