New Colors - Are They For Real?
Autoblog and other news outlets are reporting four new colors for the 2012 Silverados: Silver Ice Metallic, Mocha Steel Metallic, Carbon Flash Metallic, and Graystone. Some of these sound like returning colors from older model years, but whatever...I've always like metallic black colors, and I think these trucks would look sharp in Carbon Flash.
Anyway, GM's own online order/reference guide makes no mention of any of these except for Silver Ice. Who should I believe? Does anyone out there work for a dealer with good ordering info?
TIA, and sorry for the questions...like everyone else, I just want to make the best purchase for myself. :)
I am not sure of the colors and cannot answer your question
The reason I am posting is that you should not be sorry for asking a question. EVER!
The carbon flash metallic is basically black granite metallic renamed. The carbon flash metallic can be seen on the 45th anniversary edition camaros. This is a really sharp color. Have seen it in person a few times
i know it is impolite to stare, but..... :fume:
same with Mocha Steel Metallic but its a GMC color name
according to the order guide these are the 2012 1500 truck colors
Imperial Blue Metallic 37U WA-403P *4
Black 41U WA-8555
Blue Granite Metallic 46U WA-928L *5
Summit White 50U WA-8624
Victory Red 74U WA-9260
White Diamond Tricoat 98U WA-800J *6
NEW! Silver Ice Metallic GAN WA-636R *7
1 - Interior color, including seat trim, has lighter/darker two-tone effect.
2 - Vinyl seats require (BG9) Black rubberized vinyl floor covering.
3 - Requires (KB6) heated and cooled driver and front passenger seats.
4 - Not available on Crew Cab models until 4th Quarter 2011. Not available with (PDA) Texas Edition, (PEB) Custom Sport Truck Package or (PEF)
Florida Edition.
5 - Not available with (PDA) Texas Edition, (PEB) Custom Sport Truck Package or (PEF) Florida Edition.
6 - Included and only available with (PDP) LT White Diamond Edition or (PDP) LTZ White Diamond Edition.
7 - Not available on Crew Cab models until 4th Quarter 2011.
2012 Chevrolet Truck Silverado 1500 COLOR AND TRIM - SOLID PAINT ZY1
Published August 26, 2011 Page 2
2012 Tahoe colors
Black 41U WA-8555
Gold Mist Metallic 51U WA-316N
Black Granite Metallic2 58U WA-501Q
NEW! Crystal Red Tintcoat2 89U WA-505Q
White Diamond Tricoat3 98U WA-800J
Mocha Steel Metallic GHA WA-706S
NEW! Blue Topaz Metallic4 GTS WA-933L
1 - Interior color has lighter/darker two-tone effect.
2 - Additional charge.
3 - Available on LTZ models only. Additional charge.
4 - Available to order Spring of 2012.
2012 Chevrolet Truck Tahoe COLOR AND TRIM - ZY1 FOR NON-Z71
Published September 2, 2011 Page 1
    • You need a better code reader/scanner.  You are missing codes.  Did the dealer give you a copy of the SAVI scan from that visit?     If the fluid hasn't been changed, change it.  Shudder will likely go away.
    • TLDR to my other post...   Hard. Pass.  Too many what ifs.     Are you set on a 3.0 Duramax?  Have you considered anything not GM just in case?  If you don't have to have a pickup, lots of other options for $27,000 out there.
    • I see some red flags.   - No mention in the Carfax if the oil pump belt was changed.  LM2s had a 150,000mi service interval, and its got 164,245mi on it.  So right out the gate it needs about $3000-3500 for that to be done before driving it another 150,000mi.  Belt is at the rear of the engine.     - If something happens to the transmission valve body, the special coverage is expired by mileage.  That will likely be an out of pocket expense, with zero or near zero GM participation if something happened even though its in by time.   - 2020 LM2s seem to need timing chains after 80,000mi at some point.  They fixed this end of 2020/starting 2021 model year engines.  They will usually set a P0016 I think?  There is another $8000-10,000 if it needs a chain.  The main chain is at the back, secondary at the front so the pump belt would be done at the same time if it needed chains.     - Long oil change intervals.  7,000-8,000mi on average, probably close to 0% or perhaps to or beyond 0% on the OLM.  Lots of them not at the dealer which makes me wonder how much of the oil ran through that truck was the proper Dexos D rated 0w20 oil and not just gas engine 0w20, which is not the same at all.     - Long fuel filter changes, again likely taking the fuel filter life to 0% or more.  First one went 28,603, second was done 43,094 miles later at 71,697, from there another 46,452mi to 118,149mi, and then the most recent one 37,026mi later at 155,175mi.  So counting its original fuel filter, its had only 4 fuel filters on it.  No bueno IMO.         Good news?    - It has had only two warranty trips to the dealer.  The first free service (end of December 2020 on the Carfax), and the transmission reprogram recall (end of August 2025 on the Carfax).     - Truck did a LOT of moving, so that might explain the lack of emissions related repairs like bad NOX sensors, bad exhaust temp sensors, bad glow plugs, etc.         The "emissions system checked" could just be how something was flagged for Carfax.  GM dealers have to do SAVI reports for warranty repair orders so they scan the truck.  So its possible that is there for that?
    • Thank you, @Z45!   NOTE - No all repair shop/Dealers reports to Carfax   That is my main concern.  The CARFAX looks way too clean for a 6 year old anything with 164,245 miles.  Even something known for reliability (like many Toyotas) typically has a lot more replaced, like a Nav screen, interior trim, shock/strut, or brake pads.  And surely the last set of tires (installed at ~58k miles) would be bald unless those were all highway miles.   I'm tempted to pay a local dealer to look up the VIN, but am not sure if that will be worthwhile.  Last time I did this, it was 100% useless, and I felt scammed - they noted the bumper was replaced years ago and that's it.  A 5-year old could spot the accident damage, even though nothing was on the CARFAX.   After giving the dealer a call, the truck may have a hard shift, but they have to verify with their mechanic if that's even a concern.  And I've test driven about a dozen of these now, many near Chicago, and half the trucks shift hard/odd at all throttle positions.  The ones with aftermarket lifts/larger tires shift terrible, and 3 stock trucks shifted so violently I thought the transmission valve body was going out.   At this point I'm conflicted, as I need a vehicle, and am coming up short locally.  Northern trucks in this price range tend to have either multiple owners, a lot of mods (lifts/oversized tires without re-gearing), and are generally in rougher shape.   If this truck showed up in your neighborhood for $27k and you had to purchase it sight-unseen, with the possibility of needing a 10L80 rebuild, torque converter, or rear end - would you do it?  I'm convinced most of the 10L80 trucks I test drove are broken, they can't all shift so bad, with massive flares/slipping/lurching and mis-matched downshifts like a teen driver learning stick.
    • From the spy shots, the front end does look like it's borrowing some styling cues from the Canyon. I'm more interested in the powertrain news than the screens though. If the 3.0 diesel survives into the next generation, that alone will keep a lot of current owners interested.
