Oil Catch Can
Is any body useing an oil catch can on their 5.3 or 4.8. Does it work? What brand do you have? Any problems with it?
The catch can mounts between the PCV and the intake. It is supposed to catch any excess oil that may get into your intake.
Thanks and have a great day,
Don :cheers:
well i have never used one on a truck before but i know they come in handy reducing the amount oil in the intake, and in turn slowing down carbon deposits.
Im using the AMW along with the LS6 valley cover.  Intake is spotless.  The new PCV wont fully cure the problem.
I installed the AMW catch can yesterday. I am using the stock pcv location. Every thing hooked up real well. Seems to function perfect. Hope this keeps the 5.3 clean.
Don
Is that a vent on your oil add tube?
Yes it is. The vent tube that ran from the pass side valve cover to the TB was barfing oil into the intake. So I plugged off the line and fashioned a breather. Never a problem since day one I put the 6.0 in.
F-body guys were doing it with no problems too.
And my intake was freaking SPOTLESS!!!!!!!!!!!!!!!!!
  • 3 years later...
Just installed a Lowe's/Kobalt catch can I had left over from a Pontiac G8 I got rid of. Installed it in the pcv vent line from the driver's valve cover up to the plastic intake manifold. Anxious to see if it does anything positive.
Just like I said, new people to the truck fraternity need answers, too. And revitalizing proven information leads to better products. This 65-year-young old fart is still doing stuff. Sometimes, outside the box!
You go dude..... I started this thread and have had a AMW catch can since 2006. A real one...not an oil seperator from Lowe's...
http://www.accmachtech.com/catchcans.asp
Old thread however here is my catch can. It is a custom set-up using an LS6 valley cover. Ignore the cheap lines and tiewraps...it was test fitting and mock-up in these pics:
After about 2K miles I drained it. The system worked great!
    • She's laughing all the way to the bank.
    • There's a new PI on 2023-2026 L3B shudder.  Possible faulty front oxygen sensor.   Dealer can pull up PIP6060A and give it a read.
    • Also here's the drive cycle for a 2021 Yukon with V8.  DO NOT USE THE CRUISE CONTROL WHEN RUNNING DRIVE CYCLE!!!!!:   Warning: Road test a vehicle under safe conditions and while obeying all traffic laws. Do not attempt any maneuvers that could jeopardize vehicle control. Failure to adhere to these precautions could lead to serious personal injury and vehicle damage. Note: You have completed this procedure when all parameters display Complete. Short stops for traffic will not affect the procedure. Note: Do NOT use cruise control during this procedure. Ignition/Vehicle » Off — For greater than 8 h Verify the scan tool parameter: Cold Start-Up = Yes If not the specified state Ignition/Vehicle » Off — For greater than 8 h & Repeat this step If the specified state Ignition » On / Vehicle » In Service Mode — For 1 min Engine » Idling — For 2 min Drive the vehicle while maintaining the following conditions for 20 min: Part Throttle Vehicle Speed = 24 to 97 km/h (15 to 60 MPH) Safely stop the vehicle Operate the engine/vehicle within the following conditions: Accelerate the vehicle to 64 km/h (40 MPH) Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 10% and 13% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 13% and 16% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 16% and 19% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 19% and 22% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Accelerate the vehicle from 64 to 97 km/h (40 to 60 MPH) @ Throttle position between 22% and 25% Release the accelerator pedal and let the vehicle coast down with the brake pedal released — For greater than 20 s Maintain steady state throttle at 89 km/h (55 MPH) — For 10 min Safely stop the vehicle
    • About the only GM that compares well with its competitors through the small to midsize vehicles is the Trax. I would like nothing better to just drive GMs. My wife in a Cadillac me in a Chevy minivan and Colorado. Part of my day is comprised of reading and watching comparisons of automobile. I could buy a car today. I’m back to research the next.
    • Do you have any DFM defeat devices like the Range modules?
