99 Bravada Transfer Case Sensors
I bought a 99 Bravada with 71,000 miles. It had not been driven in 2 years due to the SmartTrak not disengaging. I have replace a front axle and still not working. Checked the fuse and was blown. Took it around the block and worked fine. Changed the transfer case fluid, oil, etc... Now it's blowing fuses as soon as you pushthem in. I have determined that a sensor or the wiring to this sensor is shorting. The sensor is located on top of the transfer case. What sensor is this and would the sensor cause the fuse to blow?
