Nbs Owners...afm Problems. Must-read
Just found out about a new TSB from GM. Deals specifically with NBS and 5.3 / 6.0 engines.
People are complaining about cold-start tick that lasts for around a minute.
Turns out, the AFM lifters are failing. Already.
GM has authorized replacement of ALL lifters, if the customer complains of a rattle / tick on cold starts.
PIP 4344
document id 2065710
What the heck?? At least the engine is quiet in my NBS '08...does this mean it will get loud??
Doesn't GM test this stuff before it goes into mass-production ??? I'm sure alot of us are really starting to lose some faith here...
GM and other MFR's test ,test,test but the problem is the supplier. They make a contract to make a product and then when GP3 production parts come out its been cheapened. Result is failures. I have seen it for many many years. This does not just apply the Cars & trucks but everything.
gmLogoFlat.gif Service Information
Document ID: 2065710 #PIP4344: Short Duration Cold Start Lifter Tick Noise - keywords 5.3 6.0 cam engine L76 LC9 LFA LH6 LMG LS4 LY5 oil pressure start - (Feb 18, 2008)
Subject:Short Duration Cold Start Lifter Tick Noise
Models:2007-2008 Chevrolet Avalanche, Silverado, Suburban, Tahoe
2007-2008 GMC, Sierra, Yukon
2007-2008 Chevrolet Impala
2007 Chevrolet Monte Carlo
Equipped with the 5.3 or 6.0 Active Fuel Management engines
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065710&from=ns#ss1-2065710">
Condition/Concern:
A customer may comment on a cold start engine tick noise. The noise explained may be an extended duration noise related to AFM (Active Fuel Management) valve lifters. The noise may repeat on subsequent cold starts. Noise will be camshaft speed and may last over 1 minute. Noise will only occur after a cold soak that is greater than four hours in duration.
<A href="http://gsi.xw.gm.com/si/showDoc.do?docSyskey=2065710&from=ns#ss2-2065710">
Recommendation/Instructions:
Complete the current SI diagnostic for any symptom or DTCs found. If an extended duration lifter tick noise has been verified (usually greater than 1 minute), and the noise is considered excessive and repeatable, lifter replacement may be required. To repair this concern all lifters should be replaced with lifters obtained through GMSPO. There is no special part number necessary.
Note: The 6.0L engine, RPO code LFA has been built with updated lifters since 1-28-2008. 6.0 LFA engines built prior to 1-28-2008 may need the lifters replaced if the customer concern is as described in this PI.
Note: If a cold start lifter tick noise has been verified on any other 5.3L or 6.0L AFM engine, lifter replacement may be necessary. These engines (L76 LC9 LH6 LMG LS4 LY5) do not have a build date released for updated lifters.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
999999994.gif WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© 2008 General Motors Corporation. All rights reserved.
This is not good. The AFM is one of the few things I do not like about the GM trucks. I wish they would just eliminate it all together.
I was told several months ago that the AFM was going to be an issue with these trucks. I guess they were right.
So if you are willing to put up with the ticking at start up, is there really any risk to just not caring about it?
I have never heard the ticking by the way, but then again I've never listened for it.
What a bunch of crap sometimes I wish I waited for an 08 instead of jumping the gun and buying the first year model. Sometimes, it sucks being a ginnie pig...
Josh :M16:
    Mistycool
    Mistycool
  • Who's Online   4 Members, 0 Anonymous, 1,768 Guests (See full list)
    • I am having similar issues.. 08, 4.8L granted I did had a fender bender and minor damage up front passenger side but I don’t think it had anything to do with it.. I had the high and low pressure checked and my fan for my radiator keeps coming on.. replaced the pressure switch and don’t want to keep throwing parts at it. I did have some minor problems here and there like on long road trips sometimes the ac would get a little warm and then on the highway as soon as I give it a little gas or get a little heavier on the petal it started running cooler. Never had an issue with the ac besides the here and there.. but I also started having issues when I fuel up now it takes a bit to start ( super embarrassing) it runs fine and once started ( only happens after fueling up) starts fine any other time. Could they be related?
    • Spent a small fortune on fuel this weekend.   $6.69 diesel, 18 gallons of that. $6.99 92-octane ethanol free, 10 gallons of that for yard machines $5.59 87-octane for one of the cars, 11 gallons.   $250+ and I didn't even get a tug.   Hormuz ain't Hormuzin again, did not see that coming...LOL
    • Appreciate the advice. I've watched multiple videos. Most showing the most complex for those that have a center console, to one that showed maybe 2 pieces of trim being removed, like 6 screws, pulling back the screen and switch assembly, and installing the inline module. And this was a new/newer Silverado. That didn't look too bad. All the others show alot of trim pieces that need to be removed. I've broken those kind of tabs/clips on my C8 Corvette trying to get to the battery, and that was a lot less clips than what I think is involved here after watching multiple videos and looking at my dash today. I have one on the way. Called a reputable stereo place about installing it and got a "minimum" price of $175. Ouch! Looking forward to seeing what the instructions have to say.
    • Hard to say what the issue might be. Anything from the ability to cool the AC condenser up front, to blend door issues in the HVAC unit, to refrigerant charge, to compressor issues or issues in the lines.   Report back what the techs find on the 29th.   GM has service publications which list acceptable vent temperatures and AC pressures at given ambient temps and humidity. They probably won't touch the system if it's operating within those ranges.   I'm also surprised to hear your 2024 with the L8T is still using R134a? I was pretty sure the HD's had switched to the new refrigerant around 2020.
