Gotta Love Owning A Truck.
04CCSO
I had some old overgrown bushes that needed to come out, three total. What else is a guy to do but pull the truck into the yard and get out the chain. :seeya:
Clean up was a bitch!
The only reason these days to plant bushes I think is to be able to pull them out with the truck later on. :)
All my stuff is pretty low maintenance, but I do miss having bushes to pull out.
Should have tied all 3 together.
Then you could have had more time to drink additional adult beverages.
:lol:
Believe me I drank plenty of adult beverages by the time I was done.
Agreed. That's part of the reason these came out. I hate mowing around stuff. Besides that my yard looks way bigger now.
Nice pics!
I attempted something like this years ago with my 79 Malibu wagon. Unfortunately, the bush won and tore off my tailgate. Damn those beers! :):thumbs:
  • 1 month later...
We live here in Florida, Hurricane capitol. I had a 64' oak go down in '04. The city said if you can get it to the curb we'll take it. Well after cutting the tree up to a 10 stump I hooked my new '03 2500HD 6.0 gas 2wd to a 11' root ball and started draggin'. I had a friend of mine that worked for the city, when he got to my street he called me and asked how I got it there, I told him to look at the big white truck in the driveway! He's a F$%^ guy and didn't believe it till he saw the marks in the street. Today it only has 32k on it and no issues. Just use it for towing. But they tore my yard up trying to load it in the truck,,,,,,,, :lol:
    • Thanks @newdude, guess I'll keep looking.  Test driving so many trucks that have obvious things broken, I'm thinking "if they couldn't even be bothered to fix the power seat," what else is broken".   Just drove a 2021 where the power seat motor was grinding/binding and wouldn't do anything but make a terrible sound.   An owner that puts dents on the bumper, doesn't fix a seat motor, and had spotty service intervals (along with missing major services) doesn't give me the best of confidence.   Amazed at the number of people that will finance a $60k+ truck, run it into the ground, then trade with a loan balance (every single one had "loan/lien reported" on the CARFAX at the last year of registration).
    • Not true! I have been runing them since 2006 F250! suspension component that works as a sway bar, a traction bar, and a helper spring points directly to the RoadActive Suspension (RAS) kit. Works as a sway bar, a traction bar, and a helper spring.
    • Here's a starter kit:    CC Jensen, a Danish oil testing Concern gives us the following guidelines:   ISO 14/12/10 Very Clean Oil ISO 16/14/11 Clean Oil ISO 17/15/12 Lightly Contaminated ISO 19/17/14 New Oil ISO 22/20/17 Very Contaminated and not suitable for any service.   In addition CC Jensen gives a table showing how engine life is increased by cleaning up the oil. For example cleaning the oil from 19/17/14 to 13/11/8 will extend motor life by a factor of 6X.   But even cleaning it two “Life Extension Classes” will double motor life. So perhaps giving those classes would be useful:   21/19/16 20/18/15 19/17/14 18/16/13 17/15/12 16/14/11 15/13/10 14/12/9 13/11/8   *************************************   https://testoil.com/program-management/setting-iso-cleanliness-targets/   Third paragraph from the bottom will give a starting point.    Your next question should be, okay 10um at what Beta ratio and the answer is in the graph Beta 75.   Then the next question is what is your chosen filters profile? (Purolator PL series below) The red dot is Beta 75. This was the information I obtained from MANN a few years ago. So the best filters, Purolator One, AMSOIL EA, FRAM Ultra, Royal Purple, Bosch Premium should get a doubling engine life over filters like Purolator L, any service filter from any quick lube, WIX, NAPA, STP, Mobil 1, Purolator BOSS.    And as noted by CC Jensen a 2-5 micron @ Beta 200 bypass system has the capability of a six fold improvement. AMSOIL has such a system as does Donaldson.       Now having said all that testing is the touchstone. Test the oil NEW and test it with your chosen filter. Then test over milage. Do the work, get the result. But understand this in NOT absolute BECAUSE this is one factor in isolation.   Example:    A valve spring supplier can state that with cam X and a valve train of Y grams the valves will not float to 7K rpm. is that true if the builder choose a system 20 grams over limit? Common sense must be used and limits understood.
    • This doesn't look like a GM truck. Not needed on a HD truck
    • It varies a ton around me. Some places are still at $5.00 or higher and others are way down into the $4's.   Offroad diesel was $4.02 at the one station I passed today.
