Engine Temp
Jvmac88
i have a 1989 chevy k1500 new 350 about 11,000 on it. this summer i have been using the a/c and the mechanical temp gauge i put in said it was running about 230 while driving on highway. turn off a/c goes to 190. truck had a 195 thermostat in it friends dad said to put a 185 in and my problem should be fixed. didnt help me, some people have been telling me that 230 is fine with the a/c on. i think that is too hot, i could be wrong i jsy dont want to hurt the engine. any advice appreshated!
230 is pretty darn toasty. Sounds like the radiator can't keep up with the warmer air after passing through the condenser. Did you do a cooling system flush after the new motor? Did you change the fan?
First check the radiator for any debris that could be blocking airflow. Second I would flush the cooling system. Also, I would inspect the fan clutch and see if it is operating correctly.
+1 bahzillion
Perhaps in this order though...
1. Check radiator for debris
2. Check fan clutch operation
3. Flush cooling system
i did flush that radiator when i put the engine in and the fan clutch is working also re flushed this summer. i have noticed when the air is on the compressor makes a noticeable noise, could that be messed up and putting to much strain on the engine?
Did you put a new fan clutch on when you installed the engine? Fan should roar if the clutch is working properly. Clutches get weak with age and miles. It's easy to overlook this item as being the problem. As noted earlier, is the radiator and condenser free of bugs and debris.When you're running the AC you're putting max heat load on the cooling system.
Did you check the temp with the gauge or with a data scanner. The gauge is just a basic indicator and the scanner will display digital temp. Don't rely on the gauge.
    • Idler Pulley… from what I understand GM and Chevy trucks no longer have an idler pulley.. they stretch belts for both belts… I had mine replaced by my local mechanic last year on my Chevy Silverado 5.3 z71 LT.   They have discontinued using them on 2019 through 2026 as of a Google search.
    • Good morning! I have a whirring sound coming from the engine or transmission area when driving w/o towing when I accelerate at 1100 rpm’s. That’s how it started. Yesterday it was more obvious while towing a U-Haul even when not accelerating at 70 mph. I could see where it may have been possibly shifting gears due to a slight grade and the intermittent rpm changes as the transmission was possibly lowering the gear down. It was making the sound multiple times but it is not constant. I replaced the serpentine belt and idler pulley but no change. It only does it when I’m driving. No noise accelerating while in park. Just started @ 53,000 miles. It’s not always there though. Unfortunately, I feel it may be transmission related. Any thoughts or knowledge about the 2022 tranny that anyone can share. I have 2500 miles left on my p-train warranty. Thanks to all for any help!
    • RAIN. It's dumping buckets. We needed it. What a welcome change...sitting here listening to it pour with my office window open.   Ok, not too much. It's not even September yet, we're not finished with summer yet....
    • If you have actually done it, there must be some secret tool or method of accessing the hidden bolt head that both manifold connections have. Two of the three bolt heads are staring at you in the face from below but the third one is covered by shielding and as far as I know only accessed by removing part of the fender well lining to gain access to it and even then its awful to access or from what I had seen of someone fighting with it on a video.    There is a reason why even mechanics that deal with the awkward or risky business of undoing the exhaust at the manifolds have done the same method others are doing with these L8T by flexing the exhaust if need be or just able to slip the pan out as I did without needing to touch hardware or pry on the exhaust. By rights the two seals should be replace when those joints are cracked loose as well.
    • Actually it was a lot more controlled then I thought it might be and that isn't actually when I spilled some oil. I had thought prior of rounding up a couple of longer bolts with the same thread to swap out for a couple of the front edge pan bolts and then leaving one bolt left in the back but loosened off and then using a suction device to remove most of the fluid, that certainly would have worked and while I do have a couple of different devices I could have used to suck the fluid, now having done the job once I wouldn't even bother. I had thought of buying one of those pressurized vessels to suck or new fluid in and would if I was doing a job like this on a few vehicles but with one vehicle I just didn't bother and I have pail pumps as well I could have used assuming the hose end would fit into that less than roomy space but being such a thin fluid it pumped well with a quart type pump and just kept the hose into the trans and kept swapping containers and repeat.    What I would change to the method I did though was first jack up just the rear of the truck to put on jack stands to allow more oil to come out of the check plug on the front of the pan ( and as I did, I made sure to put that drain plug back in finger tight ) then follow through by putting the front on jack stands. Also that I would have used a larger sized drain pan in the sense of covering an area wider/longer beyond the transmission but I didn't have one and saw someone else on a youtube video using a masonry mud mixing tub and bought one at a hardware store to use in the future. The main oopsy  I did and why I spilled some oil was all my fault as I neglected to follow my own plan, I should have let down the pan as I did to drain out the front of it as much as would come out but then scooped out the remainder of the oil with the Dixie cup I had sitting there just for that purpose as by that point there is enough room to reach right into the front of the pan and just bail it out basically.
