2007 Ltz Extra Battery Installation
1sof
My 2007 Silverado LTZ 6.0 has a place for an extra battery to be installed. What advantage would I gain and what is the GM kit number for the parts needed?
Thanks again!
I don't know about your specific year, but from other year wiring diagrams I have looked at, one battery is reserved for starting the vehicle. So you could run down the other battery with accessories on, yet still be able to start the vehicle.
So far as parts, a GM dealer parts department would have that information.
GM wires the second battery strictly for high loads, like plowing. The battery is only on line with the key in the run position. The only way it will help, if the main battery goes dead, is you can use jumper cables, and jump yourself.
Mark.
I've often wondered why my truck has 2 batteries.
From this thread, sounds like the 2nd battery is only for starting the truck ? (it's a duramax, if that makes any difference)
The diesel requires two batteries to supply the required amperage to turn it over. Since diesels fire by compression instead of ignition, the power required to overcome the compression is much higher than that of a gasoline engine. Plus you have a heater circuit draining even more juice.
Thanks for the clarification! :D
    rayredbone
    rayredbone
  • Who's Online   3 Members, 0 Anonymous, 280 Guests (See full list)
    • Thank You.   So far my new ride is making me look like a genius for going with the 3.0L, as my first fuel refill occurred over three weeks from when I took delivery.  This engine combination is very amazing.  So far no issues and had not done a regen yet.
    • I am curious as to how much fluid you put back in the transmission ( assuming you had replaced the filter to compare to my findings ) and then went through the process of warming up the trans before pulling the check plug to drain out the excess and if you measured how much came back out.    I just found it surprising that some claimed a certain amount less fluid being put in and then draining some back out. The attitude of the truck as per if the surface is level and how the trucks stance is would make quite a difference since the check plug is right at the front of the transmission.
