Need Bed Liner Advice And Approximate Cost
I originally got a quote for installation of a Rhino liner at $425, $475 "over the rail". That was for a standard bed, but I ended up with a LOOOOONG bed. :sigh: About how much will that add to the cost?
Aslo, what does "over the rail" mean? Do they coat just up on top of the rail, or does it come down on the outside of the body a bit, or what?
If anyone has pictures of their installs, I'd appreaciate that too. I want to get a bed liner in her ASAP.
Thanks!
Over the rail = where the bed caps would go. I did mine over the rail because that area is easily scratched. I'm not sure about long bed but mine cost 450 total for a short bed. It looks great.
My longbed was already sprayed when I bought it, but I can't imagine there would be much of any cost difference. Time and material would change very little. The hardest part of the process is the prep of the truck, if they charge anything extra, I would bet its less than 50 bucks more.
Excellent. If it is less than $100 more, I can get it done right away. Well, I could do it anyway and piss my wife off :sigh:
I have had both Line-x and Rhino.....hands down Liine-x is better. Better texture, less slippage, less easily gouged and damaged, did not fade nearly as bad, and just looked better.
I woould never do Rhino again....plus the guy was a jerk. I asked for UNDER the rail and they sprayed OVER the rail and wanted to change me the extra $75 for the extra work. I told the goofball that I wanted a new truck and I refused to pay anything for the entire job...then he said he would have the bed rails repainted. Soo, who would pay for the rental car while I had the car in the shop??? We went round and round for almost three hours and I finally started to call the cops, since he would not give me the truck without payment.....
He then agreed to charge me $225 for the whole job if I would just leave...I said ok, but I wanted the warranty included....he reluctantly agreed....
I am about as dissatisfied with the quality of the entire job as I am with the dipstick who managed the shop...give me a LINE-X!!
Sorry for venting...
WOW! No, that's OK. I like to hear bad with the good. You are the first person that's said anything bad about Rhino though. Maybe I should just consider a drop-in instead?
We do have a Line-X dealer here in St. Louis. What's the cost of Line-X vs Rhino?
Thanks!
My Line-x cost $420, however, I did get a 20% discount because I went through the dealer I bought my truck from.
Maybe I should ask my dealer if they work with 'em. I know there's a Line-X installer in St. Louis, but I didn't catch where they were.
Thanks guys!
I have to chime in as another who does not like Rhino... I much prefer LineX. I've seen trucks with Rhino where the bed liner was completely worn through, but my experience with Line-X has been that it's almost impossible to damage it unless you're specifically trying to damage it.
I had Line-x in my 07 long bed. I liked it but it cost me over $500 for under the rail.
My 09 is a ECLB like yours and I went with a Penda drop in liner this time. Less then $250 and I'm very happy.
Mike
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
