Stiff Or Sticking Gas Pedal
I've got a 90 S15, with a 4.3 and I can't get the gas pedal freed up, I've tried cleaning the throttle body,spraying PB Blaster on the springs, I removed the throttle cable clip to see if it the pedal moved freely, and it seems to, but, the throttle body seems awful stiff to me,with out the cable hooked up to it.
Any suggestions? What am I overlooking?
Did you remove the throttle body to clean it?
No I didn't I tried 2 cans of CRC throttle body cleaner,I guess that wasn't good enough uh?
Do I have to take it all apart, to clean it or can I just let it soak? Will it hurt the injectors?
