Tire Question
I can't decide between the Goodyear Wrangler DuraTrac and the Kumho Road Venture AT KL78.
The Goodyear runs $210 each and the Kumho $138. Times are tough so the Kumho price sounds good but I'm thinking the Goodyear might last longer. I've had a set of Wrangler MT's that lasted over 45k and just got burned by a set of Parnelli Jones Dirt Grips that are barely making it over 18k and don't want the same situation out of the Kumho's. Any advice is appreciated.
BTW The Parnelli Jones grab and keep on biting in loose dirt/sand and mud--Great traction. I'm not dogging them at all, I just do a lot of highway driving and the tire compound is too soft for me.
I was comparing them at TireRack.com:
http://www.tirerack.com/tires/CompareTires...ndex=87R7GEOATS
i had a set of goodyear's that were shit, i hated them, but maybe i just got some out a bad batch. I have a set of Toyo A/T's now, (because i also do a lot of highway driving) and they are ok offroad, but they last a good long while on the highway . i'm thinking of going with the kuhmo though. have read a lot of reveiws on them and they sound pretty good.
anyone else know of any other good off road tire, for someone who drives a lot of highway miles?
Of the two you mention I'd buy the American made Goodyear. Have you looked at Cooper Tires?
I'm gonna be the odd man out here and suggest a look at Bridgestone. I had the Dueler H/Ps on my 02 SD and the A/Ts on my 99 and 06 F150 4x4s. In each case, they were better than the tires they replaced. Maybe not better quality than the Michelins on the 02 SD, but better performance.
I'm no big fan of Goodyear. On my 99 F150, those Wranglers may have been the poorest tires I've ever owned. Which I didn't even realize until I replaced them with the Bridgestones. Wet traction was so bad, I actually put it in 4HIGH to get out of some tricky intersections.
The Eagle LS2s on my current truck are definitely going to be replaced with another set of Bridgstone H/Ps as well when they wear out. And I'm going to do my best to make that happen sooner rather than later! :nono:
    • Ok that confirms the extra quart theme they are still going with which must mean they have noted some initial use more so then some engines and probably the bigger factor in all of this probably isn't the engine so much as its the insane distance or OLM that lulls a lot of the driving public into driving their new vehicle off the lot and not even doing one short interval oil change because the manufacturer doesn't say different and if the dealer follows that logic as well. Selling the rarely needing to be serviced concept seems to go over well with the public that wants to get away with as little as possible for dollars spent on the vehicles maintenance and I bet there are 3.0 engines just like other vehicles out there that never have their oil checked by the owner which goes back to why they probably felt the need to add that extra quart to avoid a costly theme.    Speaking of cutting filters open, it was probably over two years ago now that a youtuber who buys vehicles to do longer term reviews and pulls a fifth wheel through the mountains of Colorado on summer trips and that becomes part of the testing. Anyway he had a GM HD with the 6.6 gas and a Ford 250 with the 7.3 gas at the same time and of no surprise the Ford had more power etc but somewhere along the way in the few thousand miles he put on the truck, he changed the oil and was seeing glitter and cut open the filter and yeah, things were not looking spectacular. The truck about that time or soon after seemed down on power compared to what it had been and then threw some engine code, I expect the cam/lifters were failing and so he brought the truck back to the dealer and made some deal to get out of it as he knew it would sit for months waiting on a new engine as they were so backlogged at the time. He kept the GM for some time after that using it exclusively until he sold it after buying his next vehicle to do a review on. Definitely the filter can tell a story when things are starting to go sideways, but it would be a sickening feeling to cut it open and be faced with an ugly mess like that and be running a magnet through the pleats and the oil on the dirty side of the filter and see all the fines sticking to the magnet.    The dealer may have some ideas based on experience as to where that coolant smell is coming from, I would imagine if they can't find it but its smelling they would put dye in it to they could give it a run cycle and use the black light to see where it pops up, if its a hose connection, water pump, rad or even a head gasket etc.
    • Good looking truck, suspensionmaxx looks like a solid option
    • Thanks for the info, im considering a leveling kit or 4" lift kit.
    • charm.li (website) has the vehicle-specific diagnostic procedure for that code, you can use to find what the cause of it is.
    • It’s at the point of amusement. I’m retired I have time. It’s fun seeing people try to convince me I’m using oil. I’m buying oil at the prescribed time. It gets drained and new goes in. Do I add in between, no. My oil doesn’t even get dirty in 5k miles. I don’t even see any drop on the stick. I check in the same place. All is well.
