New Problem?
Ok today had to haul my son and some buddies after Dodge lost a 5 speed transmission. It started to rain and one of the guys in the back said hey there is water dripping back here???? It was coming into the cab right in the middle, does anyone have any ideas about where it could be coming from? It was leaking more from the headliner area that a leaking window seal. :)
Third brake light??? If you have one that is.
+1 If the leak is at the back of the cab near the window. Is this on your '99 ext. cab?
No rear slider. I will look at getting a new gasket for the himount brake light and see if that fixes the problem. Yes it is on my 99, this is the first problem like this I have had with it. :rollin:
I don't think GM sells just the gasket....you'll have to replace the light assembly or use some silicone....
