What Is My Truck Missing?
Ok guys I'm really really happy with my truck but I just feel like it's missing something. I'm going to leave the engine as is for now. I just feel like it's missing something appearance wise. I've got a little over $1000 to spend. I was thinking ext. mods but will take interior mods as well. Let's hear your suggestion guys!
If you really want help spending all your money, I'd suggest posting some pictures of your truck in this thread or at least a link to some pictures of your truck. That will give people a better "view" of your truck, so that they can figure out what they think is "missing." :)
Best of luck! :omg:
Sounds like you got a bad case of $1000 burning a hole in your pocket. :omg:
Put a grill on it, couple hundred bucks...be done. You already have wheels you evidently like. Don't just put crap on it just for the sake of putting crap on it. Otherwise it'll end up looking like a pimp ride.
The only thing I think it's missing and no real truck should be without is some "TOYOTA" badges!!!
J/K. Truck looks nice. Maybe a grill and exhaust system.
Definetly change the grille (I'm thinking either the All-terrain or a Billet) I think that will make a big difference. If you don't, at least black out the GMC emblem on the grille.
I'd suggest a grill guard (not bull bar, those things serve no purpose IMO!) some nice lights, a whinch, Line-X the bed if you haven't already, a nice toolbox...
Yeah, I've seen some wenches I'd like to have regardless of what the bed's lined with. That'd give a 6" lift :omg:
    bellssn690
    bellssn690
  • Who's Online   4 Members, 2 Anonymous, 831 Guests (See full list)
