2000 Sierra 4.8l Cold Hesitation
pkradam
Hi There,
I have a 2000 sierra 4.8l with 198000 kms. When started cold I notice the throttle is very unresponsive. It will take up to a minute appx before any acceleration will occur. The truck seems to be struggling with towing my 4500lb trailer as well. The tune up condition is ok. fuel press at idle/no load was within spec. Exhaust pressure before cat indicated no cat clogging as well.
Any previous experience anyone can share with this problem would be greatly appreciated!! Thanks in advance!
You've towed this trailer with this truck before with no problem? Or did you just get this truck?
Had the truck since new. Just got the camper this year. The truck really struggles with slight inclines and shifts quite harshly when I have to really lay into it. I don't know if the two problems are related however everything seems fine otherwise.
Check your glove box for the RPO codes for your rear end ratio or do you know it already?
Here are a few:
GT4 Rear Axle: 3.73 Ratio
GT5 Rear Axle: 4.10 Ratio
GU4 Rear Axle: 3.08 Ratio
GU6 Rear Axle: 3.42 Ratio
Also when you say "It will take up to a minute appx before any acceleration will occur", do you mean you press the pedal and engine doesn't change RPM at all?
I dont remember my axel ratio, but my tow capacity is 6400lbs. I subtracted 20% to allow for age and varailables in weights when picking my camper. My campers max loaded is actually 4500 lbs. I'm likely pulling it at closer to 4000lbs with water on as it's dry weight is about 3600lbs. I had the dealer also install an additional transmission cooler to be on the safer side. I have friends pulling similar campers with comparable trucks without much difficulty.
EDIT it's GT5 4.10
What I mean by acceleration to occur is I push the throttle and the engine rpms do not respond hardly at all. After a short period of time 15 - 30 seconds its almost like the truck goes " Oh, we are trying to go somewhere! OK let's go" and my acceleration is normal.
I put in a new mass air flow sensor and all the problems have dissappeared. I had forgotten how well this truck drove even under normal conditions lol.
    Clark_Elite
    Clark_Elite
  • Who's Online   5 Members, 0 Anonymous, 384 Guests (See full list)
    • Glad I found this post before posting a question. My ‘09 has been throwing those codes and P0442. I replaced the gas cap as it was trashed to begin with and the purge solenoid valve under the hood but still get the code every now and then. Dealership said I need to replace the vent lines as the previous owner use cheap fuel line that feels more like a balloon. They also said the charcoal canister and the “canister vent solenoid/service kit” so it relocates the filter up by the top of the transmission. Vent solenoid is cracked as the previous owner just let it hang loose. Too lazy to put it back on its bracket. If I put it on there the hose kinks and I thinks causes a whistle when I fill up.  Only issue is the parts guys can’t tell me which one I need as it shows two styles. One has a jointed section. Which should I use?  Thanks.  I apologize for hijacking the thread
    • UPDATE 3: Supposedly you need any cluster OTHER THAN a WT model cluster to have full steering wheel functionality. Went back to the part truck and removed the all terrain cluster, trim, and snipped as many wiring harnesses as possible to pull out the factory terminal leads if needed 😂 that poor donor truck…    As of right now I’m relying on Darth_Vader’s thread and YouTube videos. will update.
    • Was commenting on the engine labs article on lifter failure.
    • The “engine hours” display is there because the truck detects the key presence as you were thinking.   My first step would be to call a dealer service person and ask if this a known issue and how they deal with it. If you don’t get meaningful advice there, i would try a couple of DIY things before bringing it in for troubleshooting/repair.   It sounds like a mechanical key detection switch is stuck, but I have not actually seen what the internals look like. Maybe spray some Caig Deoxit (electrical contact cleaner) in the key hole and work the key in and out in case it’s an electrical contact cleanliness issue.  If that doesn’t work, next apply whatever lubricant GM recommends and work the key in and out a few times.    Good luck with it.
    • Carbon on valves would be the least of my worries on a light duty, 1500-series pickup with 357k provided the engine still ran halfway decently. Everything else is likely toast, on its way out, or has already been mauled to death by cheap mechanics and backyard fixes. Those kinds of trucks nickel and dime a guy to death.   I wouldn't think having the top end cleaned once or twice would be a big deal on a 5.3 but maybe it is?
