2000 Seirra Squeaking - Driveshaft?
Grip72
so my truck started squeaking and it sounds like the driver's side but I can't be sure.
It seems to be the driveshaft as we put a mark on it and then my buddy watched it as a I drove and it always squeaked at the same rotational position. There are no grease nipples for the u-joints so I'm at a lose for what it could be or how to fix it.
Can anyone help?
(i plan on jacking it up either tonight or this weekend and laying underneath while the wheels turn to get a better look, but i just want other opinions or suggestions on what to look for/possible causes)
if it is the u-joints, how hard are they to replace? expensive?
Do you have the 2 piece d'shaft? If so, look closely at the carrier bearing in the center.
Be sure and use jackstands while you're under there. Does the sound happen when you first start moving and when you're stopping? If you suspect the the u joints after your next inspection then the best way to check your U joints is to remove the d'shaft and then rotate the joints by hand. You can tell if they're rough, stiff or loose. The loose you can tell when on your vehicle most of the time. You can change them out yourself. You'll need something to press them out. A big bench vise or a press will work. One thing you might do is remove the d'shaft and take it down to someone who can press the old out and the new in. Most driveline shops will do this for you. Just take your new joints with you. Parts are not expensive.
thanks for the advice
and yes i'll use jackstands. it is not a 2 piece driveshaft. it does it when i take off, not under braking though. just leaving stops. i can't tell if it's doing it at highway or higher speeds because there's too much noise. but ya it's super annoying when i leave lights or stop signs!
That's usually the way it goes. Be patient it'll probably be back. You still might pull the d'shaft and feel the ujoints as you rotate them.
    • Indeed a proper drain tap or drain valve with adapter that has a hose on it that opens up the valve as the adapter goes on is a slick setup and have that for certain highway tractors etc and other equipment that came from the factory with a tap but this L8T is pretty darned good other than me doing it on the floor and easy to touch hot exhaust and am not as agile as I used to be !. If I really want to pull a hot filter on an engine I will use an insulated set of thick neoprene gauntlet gloves but I am not in the hurry I used to need to be so things are done more relaxed and in theory somewhat safer ... I think LOL.    And as I mentioned the unique shape of the Amsoil 1 quart containers, while they might not work as well as an offset pour spout container for some awkward engine location applications, they are working a lot better with my Lisle funnel kit because of how they prop up on all four corners when upside down resting on the rim of the funnel where the typical quart container would never stay put without holding onto it.
    • Well, I just hit 100K a few weeks back, and I can honestly say I have not had any major issues with my '21 5.3 Crew cab.  I have done most routine maintenance, oil changes, air filter, tire rotations, and a transmission drain and filter change (not even a full flush).  A couple of months ago, I started experiencing the dreaded CLUNK when coming to a stop, sometimes hard enough to literally push the truck forward! After researching here and in other forums/youtube videos, etc, I was thinking it's the slip yoke. I finally had a chance to take it to my local mechanic today, and he was not able to recreate the issue.  Amazing, since it does it nearly every time I drive.  He also said he can't simply grease my slip yoke/driveshaft splines, because I have a 1 piece driveshaft.  I am not sure what else I can do.  Has anyone else had this issue or have any idea what else it could be?
    • This is where the Fumoto drain valve comes in handy.  No mess and able to change oil hot, like right off the interstate hot.  Flows nice and you can direct it into a container. As for the oil filter, I use an old dixie cup or plastic one from McDonalds. It contains the oil as you pull the filter down and not all over your hand.
    • Well, if it did change from lifters to rocker arms, at least it would be easier to fix as they fail.
    • Doesn't hurt to try.  It's my understanding that you have to run it at least 4 or 5 oil changes for things to get clean.  Think about it, your engine didn't get dirty in just an oil change so over time it will slowly clean. It's the safest way to do it and not have seal issues.      I remember  a product that came out a long time ago, AutoRX, it was an additive you put in the oil and then drove for 3k miles. Some saw improvements and some didn't. It was suggested to use a non synthetic with it at the time. Same observation, use a couple oil changes and give it time to work. It also stated it worked best if you could drive on trips to keep the oil hot.  I'm sure if you ask AI it could tell you all about it.
