Soo Many Choices... Need Help
lsuguy
20x9. Get +18 offset if possible. Don't go any lower than +12 and no higher than +30
+1 ... and forget about a x10
So I haven't bought any wheels or tires yet. School's been crazy and have been really busy lately. I'll be stopping by a few local shops this weekend to get some price quotes from them. I think I will go with the Monsters. As far as tires I keep going back and forth. AllBlkdOut07 posted this pic on one of my other threads
I really like the Discovery STT's. Especially on the stock alloys that were powdercoated. What I'm curious about is will the size 33x12.5R20 be the same as the 305/55/20? How do these tires ride and are they known for being pretty good tires?
The answer to both questions is yes. 305/55/20's are the equivalent of a 33x12.50, and Coopers are excellent tires.
The bottom two wheels you posted pics of are too gaudy.
If you like the top wheel(Monster?) take a look at the American Racing ATX series Artillery or the Marin.
Also this place has great deals on AR, lowest prices, no tax, and free shipping on American Racing wheels.
I'm leaning towards the Marin in chrome for my 2010 GMC Savana.
http://www.wheelsforless.com/detail.aspx?ID=6620
http://www.wheelsforless.com/detail.aspx?ID=877
  • 3 years later...
This right here answered my question!
XD monsters are the only rims that show up for me, so go with them lol. and I've heard a few people saying that NItto's wear quick and the toyo's have a good tread life, so i say go with the toyo's
    President Roberto
    President Roberto
  • Who's Online   2 Members, 0 Anonymous, 999 Guests (See full list)
