2008 Silverado Interior Conversion
is it possible to take the whole inside interior from a 2008 silverado and mount it on a 2004 silverado?? does anyone know? has it been done before? any pics??
40 views and nobody can give an answer?
Obviously no one has even given this any thought....instead of criticizing why don't you give it a shot and become the answer man! BTW, if you're talking about door panels, dash, etc., since they are a part of the interior, I don't think you're going to have much luck at all.
i believe the 2008 (gmt900) trucks are wider than the gmt800's by a few inches, an interior swap like that would be very expensive and prolly impractical/impossible
I'd guess it'd be about as easy as putting a Ford interior in a GMT800. It'll fit in the door, but that's about it.
no point on getting a new truck my truck only has 40 thousand miles on it, i was just asking because they were selling me the wole interior for 250 dollars but o well thanks anyways
:lol: Whole interior for $250? You'd be lucky to get a set of seats for $250 unless something was severely wrong... or you were buying stolen parts.
Oh, and just for your information the grammatically correct statement to make would be "No point IN getting a new truck...."
:thumbs:
Hold on...if you are getting the whole interior for only $250 bucks, and assuming you have the time to do this, it might be worth it giving it a shot!
If it doesn't work, then you are just out of $250...
(you can even try to sell the used parts to get some of the money back.)
just a thought...
just a thought...
Even if the parts physically fit, I don't think there would be any chance that the controls (HVAC, gauge cluster, stereo) would work. GMT-800s used Class-II Databus for vehicle communications, GMT-900s use GMLAN. Totally different setup.
    Brendan C
    Brendan C
  • Who's Online   2 Members, 0 Anonymous, 1,235 Guests (See full list)
