09 Bose System Adding Sub
Wondering if anyone has done this with the newer bose system. Did it in my 04 with the bose and sounded great. Not working good in my 09 denali
Have dual ten inch subs and trying to hook them up using a pac loc off the back speakers but they cut in and out at random with the volume turned up a little. Wondering if anyone did this setup and how they hooked it up or where they took there signal. Looking for info on the newer style trucks with the bose system as it worked great in my 04 but wont in my 09
  • 5 weeks later...
Ive got a 2007 Sierra denali NNBS with the bose system i had the same problem but come to find out the signal coming from the bose amp has been crossed over. I tapped into the signal before the amp in the center console and ran a LOC and it work great. I cant remember 4 sure what colors they were but you can call the company that makes your LOC and they can tell you thats what i did.
