Hollywood1053 Posted October 7, 2009 Posted October 7, 2009 Anyone have their front wheel hub assemblies fail early (<30K)? I've got an 06 1500 with 29K miles and I think I have one going. It's like an out-of-balance whining - whaa-whaa-whaa sound coming from the front end. Also having some heavy grabing during braking. I've checked the pads and rotors and they look good.
GasHog369 Posted October 7, 2009 Posted October 7, 2009 on my 06 1500 i had both calipers go bad w/in 20k - 24k miles... Dealer replaced them as a good faith thing tho.. Are your rims heating up rreal bad at all or any heavy brake dust?
Hollywood1053 Posted October 7, 2009 Author Posted October 7, 2009 Not sure if the rims are heating up - I'll check next time I'm in it. No heavy brake dust.
2000DV4.8 Posted October 7, 2009 Posted October 7, 2009 To check the hub, jack up the front of truck, put it on jack stands, and grab the tire at the 12 and 6 o'clock positions. Wiggle back and forth, and see if there's any play. If there is, and it's not coming from the ball joints, the hub is bad. Check both sides.
hockeypro1411 Posted October 7, 2009 Posted October 7, 2009 My driver's side took a dump right around 50k.
txab Posted October 7, 2009 Posted October 7, 2009 Anyone have their front wheel hub assemblies fail early (<30K)?I've got an 06 1500 with 29K miles and I think I have one going. It's like an out-of-balance whining - whaa-whaa-whaa sound coming from the front end. Also having some heavy grabbing during braking. I've checked the pads and rotors and they look good. Do you have stock rims and tires on the truck?
Hollywood1053 Posted October 7, 2009 Author Posted October 7, 2009 Stock rims but different tires (275 vs stock 245x70x17).
deyomatic Posted October 8, 2009 Posted October 8, 2009 The ones on my work truck, 2006 Silverado went out around 50K on one side and then again at 80K on the other. I thought it sounded like something dragging from under the truck, definitely a grinding sound.
