What To Keep In Truck For A Flat Tire
EvanWilliams
Hi, guys. I have a 2008 standard cab Silverado. V8. 20 inch wheels I want to keep better stuff for fixing a flat than what comes with the truck. I keep a bag of stuff in the truck but am looking to add.
I have fix a flat just in case.
1. 4 way lug or buy a breaker bar. If I understand correctly a breaker bar uses an attachment that fits your individual lug. A 4 way is sort of universal in that one of the 4 will likely fit.
2. PB Blaster
3. Bottle jack or Floor jack. I once had to use the damn scissor jack that came with one of my old cars years ago and it was a PITA.
thanks for any advice.
In my truck, I have in a small toolbox in the pan (the GM one that attaches to the rail) that contains the following for fixing a flat:
- 3 ton bottle jack (can't stand scissor jacks)
- tire repair kit
- small air compressor (those little 12v things.....good enough for putting air in the tires)
- gloves
- pressure gauge
A can of that flat repair is never a bad thing to have either....good enough to get you out of a bind until you can get to a shop for a real repair.
I keep my floor jack in there, a breaker bar and Socket to fit the lugs, a small piece of wood for the jack in case I cant get to solid ground(2 feet long or so), some cardboard...so I don't have to sit/kneel on the rocks, and a fully inflated spare tire...this is key...I have seen so many people have flat spares on the side of the road.
Definitely, and I would only use it in an extreme case, like had two flats, and couldn't get a plug in there.
The other thing too, some of those fix a flat cans you have to hold upside down to get the goo out...if you hold it right side up, you have enough air to inflate a 31" tire to 28-32 psi, and no goo will come out.
Thanks guys.
Went to Harbor Freight and picked up truck box to put some of that stuff in. BTW, truck box was only 89 bucks after 20% off.
    • Thanks newdude!  By the time manual selection is needed, I'm probably too much of a control-freak to depend on the transmission sensing braking to activate automatic downshifting.  I would be anticipating the situation and already be manually downshifting.   This truck replaced a 2004.5 LLY diesel with the Allison 5-speed.  Putting it in T/H made noticeable differences (when the torque converter locked, upshift points, downshift behavior).  On this 2024 gasser with the 10L1000 I haven't been able to detect much, if any, difference.  Ok, I can never tell now when the torque converter locks up.  But I also don't notice differences in shifting.  For downhills, I've probably already manually downshifted by then anyway.  Since it's also more awkward (than the 2004.5) to engage/disengage I don't even bother.  Or maybe it doesn't really matter with just a 3k lb. camper in the bed?   Thanks also for the list of reasons the charging system might select various voltages.  However, what I am seeing doesn't fall into any of those categories.  It very definitely, and very consistently, rises after coasting/braking.  Maybe not immediately, but not very long after coasting/braking.  Very consistently drops voltage when no longer coasting/braking.  It might also be interacting with the camper battery charging (I might disconnect the camper and see if it changes the charging behavior).  I also need to recheck turning on headlights for when I want to force it to charge the camper.   Another JR, in June I converted the camper to LiFePO4.  Since it's not a good idea to try to charge lithiums directly using truck, I installed a Victron Orion XS DC-DC charger (which BTW is AMAZING!!).  Being cheap, I only had to buy that one item (besides the battery, of course) to do the conversion.  The camper OEM 120v battery charger (only 19 years old and works perfectly) and the truck feed the input to the DC-DC charger (not at the same time).  But I didn't want the camper charger feeding back to the truck so I kept the old separator.  I considered replacing the separator with a 30amp diode but that means more work and might add another 1/2 volt drop.  One thing that surprised me was the voltage drop over the long 10awg wire run, so I can only charge smoothly at 8 amps (because the DC-DC charger is completely configurable).  Another reason I don't want an added voltage drop with the diode.  I might also be a little lazy but all this work is being done under the sink with a small cabinet opening.
