My 06 2500 hd silverado did not come with factory fog lights, however, their pretty cheap online with bulbs and I want to throw a set on. I hate not having them. Its not appealing and I like the extra light.
Can someone tell me what is all involved? I know I'll need the lights and switch, which I can wire up my own really, I'm not worried about the switch being factory, however, are the brackets already there along with the connections for the bulbs or do I need a donor truck for those?
I remember doing this on a 94 ranger that did not come factory with fog lights, however all of the wiring was there including the connection for the switch but it just wasn't being used.
Any help will be appreciated,
thanks.
I might be wrong but I think the connections are already there. And if you buy the oem foglights, they should come with the brackets to install them. Order an LMC truck catalogue and check.
thanks.
http://cgi.ebay.com/03-06-CHEVY-SILVERADO-...=item5637cee689
This is where I ordered my kit from. Simple install with the provided instructions, and best of all I did not have to have my computer programmed to make them work. I personally would not have a truck with out them. I beleive this was the first mod that I did LOL!
thanks.
After you get your foglights you might be interested in this as well http://www.mrtaillight.com/product_info.php?products_id=886 what a major boost in light :eek:
I bought my set off of ebay and got the harness with the switch, relay and inline fuse for about 100 bucks, i may be wrong but i dont believe the truck is prewired for them atleast mine was not and yes i realize mine is older than yours... check ebay they are really cheap .
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
