Another New Guy
whitetruck.jpgI figured I might as well suck it up and post one if I am going to become a true member. Trucks have been one of passions for several years now. I own a 2008 Sierra Slt z71 4x4 that I received for graduation being the second vehicle and sierra z71 I have owned. I have a rough country 7.5" lift with Hoss XD rims and 35x12.5" Nitto Mud Grapplers, equiped wit diablo predator programming, a AFE cold air intake, a custom hydrogen generator build by myself, Dual Flows 40 series, Westin bull bar and Side steps, 4.10 gears , and a single 10" JL audio sub.
    Brendan C
    Brendan C
  • Who's Online   5 Members, 0 Anonymous, 970 Guests (See full list)
