Truck Wont Start!
So heres my story. It is around the single digits and teen temperature wise around here. I went one day to go start my truck and the radio turned on, all the lights and bells and whistles then i went to actually start the truck and...NOTHING. Me and my step dad tried a new battery just in case, well thats not the case. We tried to pull of the starter and take it in to get tested and he couldn't get it to come off and it was to cold to mess with it to much. So we had it towed to a shop and they went to start it the next day and BAM, it started. They couldn't find nothing wrong with it so they gave it back free of charge and i drove it around. Then the NEXT day i went to start it again and same thing, everything works except when i try to start the truck. This is really frustrating because i only have a month left here in town and i am pretty much stuck at my house unless i steal my moms impala which she usually needs. Can someone PLEASE give me any advice at all.
Thank you for taking time to read this and for helping me.
I assume it does not even turn over. I am leaning toward the PAS system which is activated by the key. Have you tried using a different key?
yes sorry, it does not turn over and i am going to go grab the spare right now and try it.
EDIT: spare key didnt work :smash: but i really appreciate the help!
just a shot in the dark but your transmission is in park position fully, maybe shift it through positions and try it again
Sounds like the starter solenoid may be frozen. I had this happen a few years ago after driving through a snow storm. Keep trying tht starter and eventually the contact will break free and make the contact. The starter will engage and the engine will start.
On that note...try tapping the starter with an adjustable wrench, or a small hammer while you have a friend turning the key...but dont hit it too hard.
yes we put it in every gear trying to see if maybe my indicator on my dash was off, i do appreciate the help though
I did go through some snow the night before so maybe this is it, i will try this tomorrow and cross my fingers that this is it!!!
Thanks
This is from my 2000 Helms manual. I recommend you spend the $135 or so bucks for the set (4 volume).
with the key on, use a screwdriver to short the two posts on the starter. If the starter works, then you know the problem is elsewhere.
How did you make out with your starting problem?
starter relay may be bad. if i remember you can swap it out with the AC relay and see if it starts, if so relays are cheep
good luck
Thank you for taking the time to do this!
Unfortunately its ben in the negative numbers lately and i cant STAND the cold, my fingers and toes freeze up way to fast and the i cant get to anything with gloves on so were just going to have it towed tomorrow and have them try one more time to figure out what's wrong with it.
Thanks a bunch everyone for helping me, if only it was warmer i could have tried a lot harder. Id rather give to someone with a heated garage to take care of it.
    • "Teardown" is complete. Head surfaces are clean and ready, new intake is prepped and ready. Coolant drained and water pump is removed, radiator is removed, new hoses and pump are ready.   The replacement intake is also from a '95 (with I think 260k, the odometer said). Noticeably less pitting where it covers the rear coolant passages. I'm not sure if that's a tribute to more frequent use, more frequent coolant changes/upkeep, or if the intake was machined at some point. But it appears I found a good one.   My coolant hoses were original, and the lower hose still retained the factory spring inside. It's not really rusty, but it's got deposits all over it. Unsure if I should re-install it (will thoroughly clean it first). Someone said hose technology has gotten better since 1995 (has it?) and I don't need the spring. I think modern EPDM is what made those hoses last from 1995-2026, so it's a question of how much suction can the water pump really pull, and will it collapse the hose without a spring?   I'm stopped and waiting for parts, however.   When I first brought the truck home, the fan was intermittently hitting the radiator shroud. I could see someone had monkeyed with the shroud (put a bunch of cardboard as a spacer between the upper/lower shroud halves. Someone said the motor mounts have likely failed and the engine has sagged. I wasn't sure I believed that. The engine is really solid in its mounts: To remove the old intake I *just* nearly permanently welded to the heads with freshly cured RTV and gasket snot two weeks ago, I literally had to use the arms on my lift and a chain with a bolt attached to the intake to pull it loose. It almost picked the front of the truck off the ground before ....scuuuuuuuuuuup.... I could actually hear the gaskets tearing and it broke loose and the whole truck settled back down. Motor barely moved.   SO, those parts I'm waiting on... The lower radiator mounts/bushings had completely failed. The radiator needs to be insulated from the rad support, and the bushings help the rad stand at the correct height. The plastic "baffle" was also destroyed at some point. Someone had attached the shroud to it incorrectly, overlapping a joint that should have been underlapped, creating another suspect issue potentially causing things to hit the fan. Broken tabs, side is busted off, and it's perma-formed/bent where it was jimmied incorrectly.   The baffle? Unobtainum. Long since discontinued from GM, of course. Aftermarket/capa/chinese? Also unobtanium. In GM's infinite wisdom, it appears there are at least two different variations whether the Blazer is 2 or 4 door, and I can't yet tell if they shared the same part with the S-pickups. Plan B, if I can't find a viable used one, will be to create a bracket to re-assemble the critical joint I need to seal a gap with the shroud. But that will bug me, it won't be...perfect.   The water pump bolts appear to have been installed with...plumber's putty. I guess, sure, if it works...? I've found a few "backyard fixes" like that. Someone's been here before....   If I can't find someone to jam bamboo under my fingernails to fill my free time this week I think I'll install the driver's power window motor and replace the rear door speaker that's inop. I've got a genuine GM "9.5" ohm working replacement. Why GM used a non-standard resistance....nevermind. Of course they did, you can get more sound from a cheap factory amp that way.   And the saga goes on...
