07 Sierra Nbs Interior Light Wont Turn On
My interior light wont turn on when the door opens. I noticed both lights work when turn them on manually by pressing the button/s. I popped off the cover thinking there was a 3rd middle light and there was not.
Anyone had this problem and figured out how to fix it. All the bulbs inside are working fine, just dont turn on when any of the doors are open.
Did you try to turn it on by turning the dashboard light dimmer control all the way? There's also a button below the dimmer control to disable the lights with the doors.
Just a sanity check if you haven't tried yet. HTH
Yep that I did not know it was there button to disable the interior lights will get ya as it is easy to bump when changing brightness of dash lights…
^^^What he said. I went a week trying to figure out why my interior lights would not come on when the door opened. It turned out that while wiping the dash down I pushed the button that disabled the lights. Simply fix.
Now I am going to have to check my truck. The lights work fine, but I thought that switch was the fog lamps. Time to actually read the owners manual maybe...
Just don't tell my wife I am about to read the instructions :flag:
Just don't tell my wife I am about to read the instructions :fume:
Fog lamps are below the dimmer, dome light disable is above it. It took me a couple days of frustration to figure that out. :thumbs:
Well i feel like a noob a little bit. Had absolutely no idea that above the interior light controls dial there was a button. First use of my owners manual. Appreciate all the help guys.
Fog lamps are below the dimmer, dome light disable is above it. It took me a couple days of frustration to figure that out. :dunno:
Yes, you're right. I couldn't remember. Mine wouldn't work the first night I had it home from the dealer. I almost brought it back the next day but I found the info in the manual.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
