v8 swap? ls1!!!
yes i'm going to pick up a 5.3 from a police tahoe in july
Nice.... keep us posted dude... LS1 are perfect transplant motors....
Jbo
well this was before the leveling kit, gonna be interesting to see how high the front sits now with the kit installed
I pulled my dads 16x7 enclosed a couple weeks ago and my truck looked soooo sagged in the rear. I have a leveling kit but was wondering if this is normal since the factory rake isn't there. I was shocked how much it sagged but maybe it was exaggerated because of the level... thoughts?
Yea I'm leveled out too and it doesn't take much weight to sag the truck out. I have a 12' trailer that I put 3 atv's on and it sags out so I bought a set of firestone airbags and it cured that problem!
i put in the ready lift leveling kit in and the rear blocks so i wouldn't have the sag problem. i hate seeing trucks ass low
So if you level the truck so it sits level and add rear blocks doesn't that raise the rear back up totally defeating the purpose of the level kit in the first place?
didnt do it to make it level. i did it so i could put 33's in and still be able tow without my headlights pointing at the sky
this is it without a load
with a load of wood from a tree i cut down in the front yard (full box) and it has e range tires on it
imagine how bad it would be without the blocks
+1 on the air bags. The best investment in my truck I have made.
I havent posted in a while, but I like this thread :lol:
26' TT, The Honda and Power wheels ride in the bed
just the bike on a day trip...
Edited by elmo
    morrislh
    morrislh
  • Who's Online   5 Members, 0 Anonymous, 891 Guests (See full list)
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
