Just Got A Loaded 2000 Z71...have Many Questions.
Inherited a 2000 Z71 Off-Road 5.3L with all the options and only 55k mi. on it. I bleed blue, but have always owned Pontiacs and not above getting behind the wheel with a bowtie on the front.
I am thinking about removing the tubular side rails from the bed and adding an A.R.E. topper, but the tailgate doesn't lock. Can this be added?
There are 3 "GM Campaign" stickers under the hood, front left of the upper radiator support...I assume this was recall work that has been performed?
The "Service 4WD" light occasionally shows up on the message center, but it seems to work fine. Is this a common problem or possibly a stuck solenoid? I think a co-worker's newer model does this too and he said it was a sensor inside the transfer case that wasn't worth replacing. Are there any other common problems with them like the HVAC control module, intake gasket leaks, or faulty head castings that my co-worker has had problems with? I think his is an 03.
I plan on flushing the dex-cool this spring and getting some yellow Prestone in it, probably do thermostat while I'm at it and Seafoam via gas tank and brake booster line.
My F-150 has stainless longtube headers with Magnaflow spun-cats and straight pipe dumped before the rear axle so I'm not stranger to loud. Having tried every combination of exhaust on that truck I'm pretty familiar how each change effects the note and output. I want the Z71 to sound like a V8 with deep / throaty note and significant output, but for my wife and son's sake I don't want the interior drone or teeth rattling. How do these trucks sound with a simple straight pipe swap in place of the muffler?
Are there any worthwhile mods for this truck?
How can I tell which gears it has?
Is there a dedicated Silverado forum?
Look in your glove box for these RPO codes...
GQ1 -- AXLE REAR, STD RATIO
GT4 -- AXLE REAR, 3.73 RATIO
GT5 -- AXLE REAR, 4.10 RATIO
GU4 -- AXLE REAR, 3.08 RATIO
GU5 -- AXLE REAR, 3.23 RATIO
GU6 -- AXLE REAR, 3.42 RATIO
G80 -- AXLE REAR, locking differential
yes, that's what he's talking about, it looks like you just have a standard axle with 3.73 gears, and no locker. If you looking to add a locker, I'd check out ARB, Eaton, and some of the bigger names, I'm not sure about availability for your truck, but I would guess someone should have one available
you can add a tailgate lock- i actually got one for my birthday that i finally installed. its the pop lock one. took all of 10 minutes. i didnt really bother to look into how it works, but it works.
from what ive read on here, a blackbear tune is that way to go. and imo ditch the running boards for some steps.
Correct,If you post the last 8 digits of your VIN I can tell you what they were. (Although I could probably guess what they were...tailgate cables,brake pipe contact,& brake hose abrasion caution)
Did you get the manual or power Pop & Lock?
Most of the time its the 4WD switch on the dash.
YE180787
Thanks!!!
My wife will be driving this more than I, so I don't plan to get too carried away like I have with my F150. Probably keep factory tuning, just do drop-in intake / exhaust mods if anything. Unless I found a hell of a deal on a canned tuner to firm up the tranny shifts. No interest in running premium in this one. My truck is dyno tuned so I know the difference it can make, but not necessary in this one. Just put some Husky liners floor mats in, going to get the windows tinted darker, and prob change out the antenna and headlight bulbs with some SS Ultras. If I do get an A.R.E. the tailgate must be lockable so I'll have to look into it. I figured it was a quick factory part swap.
Please explain.
YE180787
Thanks!!!
Yep,Those three I mentioned,plus two others were performed as well.....
GM Vehicle Inquiry System
Summary
VIN : 1GCEK19T7YE180787
VEHICLE INFORMATION
Merchandising Model : CK15753 -2000 SILVERADO LT 1500 PICKUP
Warranty Start Date : 11/30/1999
BARS Order Type : 70 - RETAIL - STOCK
Delivering Dealer :
BARNES-BAKER MOTORS, INC.
PO BOX 138
CHILLICOTHE , MO 64601-0138
Service Contract : No
Branded Title : No
Warranty Block : No
PDI Status : Paid
REQUIRED FIELD ACTIONS
Type Number Description Posted Date Status
RC 00024 FRONT BRAKE HOSE ABRASION N/A Closed
RC 00093 FRONT BRAKE PIPE CONTACT WITH BODY CROSS SILL N/A Closed
RC 02029 AIR BAG SENSING DIAGNOSTIC MODULE (SDM) N/A Closed
RC 05068 FRONT WHEEL SPEED SENSOR CORROSION N/A Closed
RC 06019 TAILGATE SUPPORT CABLE REPLACEMENT N/A Closed
APPLICABLE WARRANTIES
Description Effective Date Effective Odometer End Date End Odometer
36/36000 BUMPER TO BUMPER LIMITED WARRANTY 11/30/1999 70 miles 11/30/2002 36070 miles
72/100000 SHEET METAL COVERAGE RUST THROUGH LIMITED WARRANTY 11/30/1999 70 miles 11/30/2005 100070 miles
96/80000 FEDERAL EMISSION CATALYTIC CONV. AND PCM 11/30/1999 70 miles 11/30/2007 80070 miles
36/36000 FEDERAL EMISSION 11/30/1999 70 miles 11/30/2002 36070 miles
CLAIM HISTORY
R.O Date R.O Number Type Labor Operation Odometer Reading
05/30/2006 117699 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 44405 miles
03/16/2006 115485 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING) 42910 miles
10/29/2002 073292 # V0881 - 02029 REPROGRAM SDM 20364 miles
04/18/2001 057102 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 7391 miles
07/14/2000 049649 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - FRONT BRAKE HOSE ABRASION- INSTALL NOTICE LABEL 4449 miles
06/07/2000 048503 # N6612 - EXTERIOR LIGHTING WIRING AND/OR CONNECTOR REPAIR OR REPLAC 2744 miles
10/01/1999 E80787 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME 0 miles
Claim History Details
CLAIM HISTORY
Repair Order Date : 05/30/2006 Repair Order Number : 117699 Odometer Reading : 44405 miles
Serviced By : BARNES-BAKER MOTORS, INC.
PO BOX 138
CHILLICOTHE, MO 64601-0138
Cycle Date Cycle Nbr Case Type Labor Operation Part Comments
06/02/2006 696 01 # V1462 - 06019 - INSPECT AND REPLACE TAILGATE SUPPORT CABLES INC. H 88980510 - CBL-E/GAT N
Repair Order Date : 03/16/2006 Repair Order Number : 115485 Odometer Reading : 42910 miles
PO BOX 138
03/21/2006 675 01 # V1410 - 05068 - INSPECT WHEEL SENSOR (INC. CLEANING) N/A N
Repair Order Date : 10/29/2002 Repair Order Number : 073292 Odometer Reading : 20364 miles
PO BOX 138
11/01/2002 322 01 # V0881 - 02029 REPROGRAM SDM N/A Y
Repair Order Date : 04/18/2001 Repair Order Number : 057102 Odometer Reading : 7391 miles
PO BOX 138
04/27/2001 164 01 # V0609 - INSPECT BRAKE PIPE & INSTALL SPACER CLIP 15070819 - BRACKET Y
Repair Order Date : 07/14/2000 Repair Order Number : 049649 Odometer Reading : 4449 miles
PO BOX 138
07/28/2000 86 01 # V0486 - 1999-00 CV & GMC C/K 1/2T P/U - FRONT BRAKE HOSE ABRASION - INSTALL NOTICE LABEL N/A Y
Repair Order Date : 06/07/2000 Repair Order Number : 048503 Odometer Reading : 2744 miles
PO BOX 138
06/16/2000 74 01 # N6612 - EXTERIOR LIGHTING WIRING AND/OR CONNECTOR REPAIR OR REPLAC N/A Y
Repair Order Date : 10/01/1999 Repair Order Number : E80787 Odometer Reading : 0 miles
Serviced By : JOHN RECTOR MOTORS INC
PO BOX 399
MARSHALL, MO 65340-0399
10/05/1999 1 01 I Z7000 - PRE-DELIVERY INSPECTION - BASE TIME N/A N
