Jl Cleansweep And Gmc Sierra Denali 08 Compatible?
kmu
Haven't done one in a Sierra, but I installed one in my 2005 Frontier and it worked like a champ.
A JL Cleansweep is pretty much compatible with any vehicle. All you have to do is match up the wires on the correct channels.
i have the cleansweep installed in mine and it works great. some audio set-ups, like bose might need the summing device as well as the cleansweep. all the cleansweep does is send a true flat signal to the amps. so you can also have a eq after the clean sweep to really adjust the sound.
FWIW, I spoke to JL about the Cleansweep a few weeks ago. I was told that it was not needed for the Bose system UNLESS you have the center channel. On the standard Bose system the factory head unit sends a flat signal to the Bose amp and it is processed at that point. As long as you splice in between the head unit and amp you will have a full range signal. If you have the Bose system with the center channel, you would need the Cleansweep and possibly the signal summing interface. There are some great videos on the JL Facebook page that detail what these units do. I hope this helps.
I have one in my 08 YD. It is a really nice unit. I am using it along with their summing device to combine the 4 door channels with the 2 sub channels to produce 4 full range channels to feed my door speaker amp. I use the low line level out to my sub amp to my Stealthbox.
REALLY cleans up the sound.
BlitherinIdiot is right about the amp. The head unit sends one channel to the amp that does not fade/balance/or change volume. THe amp creates all the other channels and controls volume/fade/balance through the GMLAN network.
Thats great news, can I see pics of your set up? do you have the center channel on your bose system also?
Not a lot of pics. Here is one with the amps before I trimmed the carpeted covers and there is another of the a-pillars where I installed new tweeters. No pics of the console where I installed the Cleansweep and the summing unit. I got one of the console organizers so the 2 unites sit below the tray thet sits in the console.
I do have the center channel but I left it as it was still playing the center channel. Can't hear it with the other speakers on.
    • No such thing as regenerative braking on a pure ICE vehicle.     Regenerative braking is the re-capture of energy from electric motors and stores it in the battery pack.  So hybrids, PHEV and EVs have regenerative braking.     What you are seeing is the charging system changing modes is all.  Its likely entering charge mode for some sort of reason is all.  All of the charging modes will be listed below.   As for L10 vs D.  L10 turns off automatic grade braking.  L10 puts you in control of grade downshifts where in D it will automatically do it based on brake pedal position and other factors.  Otherwise L10 and D drive exactly the same aside from that one aspect.    Battery Sulfation Mode The BCM will enter this mode when the interpreted Generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2–3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.   Charge Mode The BCM will enter Charge Mode when ever one of the following conditions are met:   Windshield wipers are ON for more than 3 s. Climate Control Voltage Boost Mode Request is true, as sensed by the HVAC control module via serial data. High speed cooling fan, rear defogger, and HVAC high speed blower operation can cause the BCM to enter the Charge Mode. The estimated battery temperature is less than 0°C (32°F). Battery State of Charge is less than 80%. Vehicle speed is greater than 145 km/h (90 mph) A current sensor malfunction exists. System voltage is determined to be below 12.56 V When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9–15.5 V, depending on the battery state of charge and estimated battery temperature.   Fuel Economy Mode The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 A and greater than −8 A, and the battery state-of-charge is greater than or equal to 80%. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5–13.1 V. When fuel economy mode is active, the generator is not charging, only maintaining open circuit battery voltage. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.   Headlamp Mode The BCM will enter Headlamp Mode when ever the head lamps are ON (high or low beams). Voltage will be regulated between 13.9–14.5 V.   Start Up Mode When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 s.   Tow/Haul Mode (if applicable) Pressing the Tow/Haul Mode button located on the center stack, the vehicle system voltage is raised and the remote (non-vehicle) battery will be charged. Having the headlamps on will raise the system voltage and if the Tow/Haul button is applied it will not serve any purpose. The voltage is regulated between 13.9-14.5 V.
