2k Ext Cab Rear Doors Stick Baaad! Why?
Over time the rear doors have gotten harder and harder to open, like they are sticking somewhere. I can't see any obvious wear marks anywhere. It got so bad on the passenger side, that when I went to open it one day, the handle broke in my hand and sliced me pretty good on the newly sharp plastic edge. I use the driver's side now and that one is getting harder and harder to open as well.
I tried to search for the various terms, but somehow, "stuck", "sticks", "rear door" etc... have not resulted in a good cause or resolution. If I missed it, I apologize.
An educated guess is that maybe the doors are starting to sag and hang up on the bottom "latch assembly(?)" or are out of level. To my eye, they all seem to line up perfectly when closed, but maybe that's not the right time to assess it.
I have 2 kids and use these doors all the time, so it's really getting frustrating. I'd prefer not to visit the stealer on this. Thanks.
Yes, I have sprayed everywhere that has moving parts. Many times. And again.
Thanks.
Have you tried lubricating all of the latch points and hinges?
MIke
Thanks.
MIke
Probably door pin bushings, or the bushings that attach the latch inside the door...causing too much play and not allowing you to operate the latch with the handle.
this is not the first time I have heard about this issue, friend of mine had it with a sonoma ext cab. after it was about 6 years old the door just would not open?
Worn pins or bent/worn truck frame.
Could be all the above. 120k on it in Western NY. No accidents or even fender benders, though now that I mentioned it, I'm due.
Is my next step to call up some collision shops for a remedy?
If you dont know what your doing....yeah thats a good idea...
If you do, you can pull the door pins and bushings... and replace them in about 10 min. you could also pull the door inside pannel and check for excessive movement in the linkages to figure out if those bushings are gone.
It does show pins and bushings that are replaceable. You could check with regular repair shops, not necesarily a body or collision shop. Call around and see if they do door pins, good luck
Thanks all. I will take a peek at the pins and bushings. Doesn't sound too difficult. When I do get to it, I will post a follow up.
The door pins and bushing are easy and cheap. You can do both hinges for around $10.00. I had a similar issue on my 95 Blazer. The door latch is covered with a plastic?nylon something or other. It was worn and cracked to the point that part of it had flaked off and was causeing the latch to bind. Once I got that out, a few shots of PB Blaster and the door is like new.
    • you might read through the info on gmupfitter.com for your truck, to find a good power source.
    • Melling I believe is/was the OEM on the lifters who explored this problem some years ago. The white paper they generated on the topic indicated two items of note when I read it. 1.) They only fail on the switch. Prevent the switch, prevent the failure. 2.) The majority fail due to deposits messing up the timing of that switch. Anyway that's what I got from it.    Mine have always been active, 195K+ now, and my oil maintenance is surgically clean.    Of course this assumes good parts. That is no heat treat issue or machining flaws. I get comfortable that these issues are in the rearview mirror by about 30K. IMHO naturally.
    • Yes, the key seems to be with the half tons that if it has the Z71, then it definitely has the two speed. What got me was that the two speed AND the lower geared towing package option could not be chosen together the last few years unless it was mated up to the 6.2. Want the 3.0 duramax and 3.73 tow gears ... nope, can't get the two speed transfer case ( neighbor son realized that after he had bought his used 3.0 half ton .. where the frick is the low range ? ! ).    I am still unsure which truck series, the half ton or the HD truck that the original poster is referring to for sure other than yes his question is in the HD section of this forum but that doesn't guarantee the question got asked in the right section.
