2008 Chevy Silverado
I love the way my truck once i'm on the road at 70mph +, but getting there.
Here is what i mean. around town if I'm coming up to a light and it turns green....once I hit the gas it takes about 5 mins for it to go. If I want to pull out in traffic the power is totally unimpressive. I know there is nothing wrong with the truck and its got plenty of power. Why are these trucks like this? Is it the engine mangment, AFM or what?
How can I fix this?
All you need to know! = www.blackbearperformance.com
Driveability issues no more.
Do the gmt800s have as many nannies?
No, but visit the above link and get a Black Bear tune and you will think your current set up is a dog.
Remove the big brother TM system.
On my 09 Sierra I can turn off the TC, its on the bottom half of the dash with the squiggly looking road lines...
TM, TM is torque mgt not TC
The difference after the Blackbear tune will make you angry. :thumbs:
Dumb question, is the black bear tune via mail affect vs the in person tune?
Not a dumb question. That question gets asked by about every person that is interested in a tune.
Here is the order of "effectiveness" not a good term but you get the point (least to most)
Mail order tune
Data log tune
In person tune
All three are great. All three you can get the results you want, but the in person is the most fun and you get the results you want right then because you can try something and if you don't like it, change it.
Any of them will blow away your stock tune.
The nannies are on the 99-07 (OBS) models many of those owners have given high praise in response times after a tune.
My old 99 Silverado 5.3 was not as bad as my old 07 Sierra (GMT-900) with the 5.3.
    bellssn690
    bellssn690
  • Who's Online   5 Members, 1 Anonymous, 1,102 Guests (See full list)
