daniel4191 Posted January 26, 2010 Posted January 26, 2010 This is my first post. I currently have an 02 sierra and im running 35" buckshots with just a leveling kit. They fit fine but they do rub a little on the plastic inside the fender. I am looking to get a 2 or a 3" body lift for my truck mainly for the looks of it but also to reduce some of the rubbing. Im looking to spend under $400. I plan to buy the kit online and have a local off road shop to install it as i know nothing of installing something like this nor have the tools needed. But i understand that some kits dont come with all the parts needed. I need a kit with EVERYTHING down to the last nut. Any suggestions on what lift and where to get it cheap as possible? any feedback would be good
ryan_hermanutz Posted January 26, 2010 Posted January 26, 2010 You could try a zone 1.5" or 3" BL? Good luck, welcome and get post some pictures of your truck.
SeirraRR Posted January 26, 2010 Posted January 26, 2010 I would go with the Zone Offroad body lift. Alot of guys on here have those. And welcome to the site. PICS!!!!!!!
MYZ-71 Posted January 26, 2010 Posted January 26, 2010 i installed a 3" body lift from summit racing and run 35"BFG KM2`s, don`t get any rubbing unless offroading, then they will occassionally rub.
daniel4191 Posted January 26, 2010 Author Posted January 26, 2010 i installed a 3" body lift from summit racing and run 35"BFG KM2`s, don`t get any rubbing unless offroading, then they will occassionally rub. how much did that kit run you? did it come with everything needed for instalaion?
MYZ-71 Posted January 26, 2010 Posted January 26, 2010 i installed a 3" body lift from summit racing and run 35"BFG KM2`s, don`t get any rubbing unless offroading, then they will occassionally rub. how much did that kit run you? did it come with everything needed for instalaion? $279.95 came with everything, part # SUM-7810053
daniel4191 Posted January 26, 2010 Author Posted January 26, 2010 i installed a 3" body lift from summit racing and run 35"BFG KM2`s, don`t get any rubbing unless offroading, then they will occassionally rub. how much did that kit run you? did it come with everything needed for instalaion? $279.95 came with everything, part # SUM-7810053 Inclucing bumper brackets? my rear bumper is is bent. will that matter?
daniel4191 Posted January 26, 2010 Author Posted January 26, 2010 i installed a 3" body lift from summit racing and run 35"BFG KM2`s, don`t get any rubbing unless offroading, then they will occassionally rub. how much did that kit run you? did it come with everything needed for instalaion? $279.95 came with everything, part # SUM-7810053 Inclucing bumper brackets? my rear bumper is is bent. will that matter? one more question. Did you have to lengthen any hose or wiring or modify your fan? Thats a fine truck you got btw
ryan_hermanutz Posted January 26, 2010 Posted January 26, 2010 The Zone 3" kit comes with everthing you need including the directions. http://zoneoffroad.com/prod-display?dd_sav...p;dca=&dsv=
MYZ-71 Posted January 26, 2010 Posted January 26, 2010 yes bumper brackets are included as well as instructions, depends how bad and where your bumper is bent, but you should be able to make work even if you have to bend bumper into shape again. If you visit summitracing.com and click on expert advise and then instructions you can enter p/n sum-7810053 and it will give you complete installation instructions.
daniel4191 Posted January 27, 2010 Author Posted January 27, 2010 yes bumper brackets are included as well as instructions, depends how bad and where your bumper is bent, but you should be able to make work even if you have to bend bumper into shape again. If you visit summitracing.com and click on expert advise and then instructions you can enter p/n sum-7810053 and it will give you complete installation instructions. it is bent on both sides. touching the truck directly beneath the tail lights on both sides. i'll try and get a picture of the bumper on here asap
