High Speed Wind Noise On 02 Ext Cab
Hi truck people,
I get a lot of wind noise from the front passenger door on my 02 1500 ext cab 2wd, 143000 miles. Some of it also seems to coming from where the ext cab and front door meet. I have plenty of miles in other 1500 trucks in this body style and year. They were not this loud. This gets really loud, especially above 75. Sometimes it starts around 65-70. It may be a few miles before it starts on some occasions. If I draft a large vehicle or 18 wheeler, it will quite down. That beats up my paint and windshield too bad and makes the truckers mad.
I have tightened the latch points on the ext cab door and on the front door. They seem to fit nice and even at the A-post and everywhere else around the doors. The doors fit tight and must be shut firmly to latch correctly. You can easliy tell when they are not. Left and right door gaskets are not crimped and appear correct. Silicone lube helps with squeaking, but not the wind noise.
What's next? Lower the windows and adjust the upper door frame inward(bend the hell out of it)?
Put a bug deflector on it to push the wind up.
New door gaskets? TSB?
Anyone else had this and fixed it or know of a cure? Other than slowing down.
Thank you for your help.
Babyhauler
I'd like to hear what others have done for a cure to this too.
On my 99 NBS my hinges were shot.
I replaced them and the door closed like butter and wind noise disappeared.
Unfortunately, I wasn't aware that the door check was busted too.
Eventually, the door over opening screwed the hinge again.
Sag & wind noise have returned.
I picked up a new door check.
Got to get a new hinge kit and do it all over again.
Hopefully for the last time. :lol:
On my '01 Sierra C3 the hinge appears to be fine but yet I have wind noise also (Just bought this truck last week).
I believe in this case I will have to massage the top of the door a tad and persuade it to keep quite. :crackup:
Looking forward to seeing how others have handled this.
Big John NYC :rollin:
Andy, I think I had the same problem as you with my 05' Silverado extended cab. Like you, I tightened the door latches and all but the wind noise was still there. Then I replaced the window latch with a shorter (I think) one. This sucked the pass rear window in tighter and the noise disappeared. This was/is a common problem. I got new window latches off ebay. Let me try to find you some links.
*edit, found an ebay link for latches. But first, you can do a small test to confirm that the noise is coming from the rear window. With a passenger sitting next to that window, get the truck up to speed until it starts whistling good. Then have the passenger slowly apply force outward on the window near the latch. If the whistling sound intensifies with force like it did on mine, the new latch is likely your solution.
Link: http://cgi.ebay.com/ebaymotors/Wind-Noise-...sQ5fAccessories
Thanks for the info.
There seems to be some noise from the back door/window area. I think mine is primarily coming from the A-pillar area. It is not a whistle, just loud. I will definitely test the back windows as the sound can fool you sometimes. Any other ideas if this one does not work?
Thank you,
Babyhauler
I just went out and checked the back window. The top and bottom corners flex out fairly easy. The gaskets seem to be laying flat without a lot of give to them. Has 8 years of being mashed made them less effective?
Also, the black trim piece that runs up both sides of the windshield will easily flex out 1/8-1/4 inch on the passanger side. Enough to make alot of noise I would guess. I do not know how those attach properly. I cannot imagine a trim piece on a windshield should be that loose. Duct tape test time. Any windshield installers out there?
Thanks
Babyhauler
My problem turned out to be the 3 - 7mm bolts holding the window frame in were loose. Try that first, then the latches.
    • A complete delete is the most thorough mechanical solution, but it is also major engine work. On a quiet truck that is still under extended warranty, opening the engine purely as prevention is difficult to justify. A plug-in disabler stops commanded cylinder deactivation, but it does not remove or repair the collapsible lifters, so it should not be treated as failure insurance. I would keep the oil full, document the maintenance, and have any persistent tick, misfire, or loss of power diagnosed promptly. If the engine eventually has to come apart, that is the logical time to compare an OEM-style repair with a complete delete. The right choice depends on the truck’s symptoms, warranty status, expected ownership period, and whether the engine already needs to be opened. We explain that decision in more detail here—full disclosure, this is our own guide: https://www.bluev8.com/blogs/news/do-you-actually-need-an-afm-disabler   One exception: some 2021 L82/L84 trucks have RPO YK9, meaning cylinder deactivation was already disabled in the factory ECM; on those trucks a plug-in disabler is redundant, although the AFM/DFM hardware remains inside the engine.
    • Brought my 2015 Colorado into the dealership to check my touch screen issues, had that ghost touch thing happening. They said I needed a new touch screen and they could either order me one for $500. The lady at the service deck was nice enough to tell me I could order a touch screen online for less, she did stipulate that the touch screen had to be factory OEM, you can't pair an aftermarket screen to my radio seeing it was 2015, it had to be a GM factory OEM only. I found a few on Amazon and Ebay by the numbers on the back of the old screen, DJ080PA-01A GM# 22740886, Some said "OEM" in the description and others just said "Replacement". Would a replacement be the same as a OEM as long as it had the same numbers on the back of the screen? In some of the descriptions they also show different brand names but same numbers, is that an issue?
    • I have both but typically use the 4 legged walker (wheels on front, ski's on back).   The four wheeler is starting to be used on "longer" outdoor walks.  The 4 legged walker is particularly helpful in practicing good walking posture.  Both of my knees are at different stages of recovery and I'm trying to not develop poor habits.  I can actually manage with a cane but it's very difficult not to favor one leg over the other.  My PT recommends I continue with my 4 legged walker for a while.  Yesterday was four weeks since my last knee replacement and I'm excited about my progress to date.  It has been a hell of a rough journey so far but it is exciting to witness  systematic and continuous improvement.  I went for years watching the decline of my "mobility".  It seems that everyday now I am alerting my wife to something I can do now that I couldn't a day or two ago!  I encourage anyone facing the prospect of knee replacement to share any concerns with others who have had the surgery.  It isn't an instant fix but rather is a considerable amount of short term pain for long term gain.  Recovery time and pain levels vary for individuals post surgery but the end results are typically very positive and I've never encountered anyone regretting having had the surgery.
    • The lifter issue can be dealt with by shorter oil changes and quality oil IMO.
    • Got heavy rain, hail and light rain yesterday.
