New Guy Looking For Info
Rustybull
Already posted my questions but I'll introduce myself!
A few months ago I decided to test drive a 2003 1500 4.8. Really liked the truck (and got to chirp the tires with tow/haul!). Since my Taurus is facing imminent rust death, I'm looking around for something else.
I'm a closet GM Guy .... old Suburbans and Regals and Ninety Eights ... Lets not forget the old Detroit Diesels and the C50/60/70 trucks! mmm. I do fly the blue oval though.
Right now I'm doing an internship and when I find a job ... if I find a job ... I am going to be buying a truck around 12-8 years old. Hopefully something rust free!
Welcome to the site
Welcome and good luck on the search for your truck as well as the job hunt.
Thanks!
I'm afraid the truck hunt will be easier than the job hunt. If the job hunt gives me an excuse to move south ... all the better!
